Welcome to Doom9's Forum, THE in-place to be for everyone interested in DVD conversion. Before you start posting please read the forum rules. By posting to this forum you agree to abide by the rules. Domains: forum.doom9.org / forum.doom9.net / forum.doom9.se |
#32162 | Link | |
Like I said, there was a flag that was not set properly and that was it. English is the commentary track. This movie is not dubbed. Language is Japanese with English subtitles only. |
#32164 | Link | |
In the end I answer myself, I have managed to do the complete conversion from BD to UHD "full backup" with custom resize and with nvec encoder main 10 h265, recorded on disk and played on Xbox One perfectly. Where can I find the hidden commands that do not appear in HIDDENOPTS. TXT? I found these commands by reading you UHD_CONVERT_ENABLE=1 UHD_V3_MODE=1 UHD_ALL_MODE=1 Code:
[Options] VERSION=0.62.0.12 ENCODER=1 MODE=0 ARCHIVE_LIMIT=0 ARCHIVE_265=1 ARCHIVE_ENABLE=1 ARCHIVE_QUALITY=4 UHD_CONVERT_ENABLE=1 UHD_V3_MODE=1 UHD_ALL_MODE=1 ENCODE_QUALITY=4 REENCODE_MENUS=0 ONEPASS_ENCODING=1 AUTO_QUALITY=0 AUDIO_TO_KEEP=all SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 IGNORE_3D=0 CONVERT_WIDE=1 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AUDIO_DRC=0 DECODER=0 AVCHD=1 REMOVE_WORKFILES=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 FRIMSOURCE=0 COMPLETION_BEEP=0 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 PGSTOSRT=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=25325 NVENC_CAPABLE=1 TARGET_SIZE=24000 WIDE_PERCENT=40 WIDE_OFFSET=.85 MOVIEONLY_TYPE=40 ALTCRF=23 ALT_TARGET=1024 ALT_CRF_TARGET=190 ALTMETHOD=3 ALTAUTOCROP=0 [Paths] SOURCE_PATH=F:\ WORKING_PATH=L:\TEST BDREBUILDER\
#32165 | Link | |
Special SeeD
Text ID : 4608 (0x1200) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 According to your logs your subtitle track is in "1200" but UHD Blu-ray specs for HDR video requires subtitle track in "12A0". Because of this your player does not "see" your subtitle track. |
#32166 | Link | ||
![]() Join Date: Oct 2001
Since the original was 4K -- it would lead one to believe that the original was improperly authored?
jdobbs.softworks@gmail.com Last edited by jdobbs; 23rd February 2025 at 17:57. |
#32167 | Link | |
Special SeeD
I'm currently having the inverse situation, original BR is using 1200 for subtitles in a SDR H265 playlist but BD-Rebuilder is using 12X0, resulting in missing subtitles when playing on my hardware player. Using BDEdit to manually correct the values works fine. |
#32168 | Link | |
jdobbs.softworks@gmail.com Last edited by jdobbs; 24th February 2025 at 14:59. |
#32169 | Link |
Big Bit Savings Now !
![]() Join Date: Feb 2007
From BD-ROM V3.2 UHD Format Specs 2018:
Table 3-6 lists all 6 combos of HDMV HEVC resolution, transfer_characteristics and bitdepth: 10-bit SDR is legal in FHD and UHD as primaries BT-709 and BT.2020 with with transfer_characteristics 1 resp. 14 10-bit BDMV HDR is legal in FHD and UHD as primaries BT.2020 with transfer_characteristics 16 (ST 2084) Framerates 23.976p,24.000p,25.000p,50.000p,59.940p,60.000p. No 29.97p, no 30.000p, no interlaced ! 8-bit: only AVC, only BT.709, only FHD, only 23.976p and 24.000p, no interlaced !
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 24th February 2025 at 03:10. |
#32170 | Link | |
jdobbs.softworks@gmail.com |
#32171 | Link | |
Oh well. |
#32172 | Link |
What error was it? PredictAndEncode just tells me what routine it was in. The numbers tell me the error number and where it happened.
#32174 | Link |
OK, rework of the Godzilla title was interesting. This time around, the title did not fail encoding. What did catch my eye was that the config file was set for 45+ GB as the target. But, in the end, it was only 37 GB. That was a big miss. As originally reported, the subtitles were not seen. The subtitle playback was set to on at movie start. So, the bug is confirmed.
Here is the log: Code:
[07:48:39] PHASE ONE, Encoding - [07:48:39] Processing: VID_00005 (3 of 3) - [07:48:39] Reencoding video [VID_00005] - [07:48:40] PredictAndEncode() 00070 2810 [07:48:49] - Aborted by user request ---------------------- [03/06/25] BD Rebuilder v0.62.12 [22:47:04] Source: GOJIRA_AKA_GODZILLA_1954_CRITERION_2160P_USA_UHD_BLU-RAY_HEVC_LPCM_1.0-HORROR - Input BD size: 67.21 GB - Approximate total content: [01:37:41.855] - Target BD size: 45.90 GB - Windows Version: 6.1 [7601] - Quality: High Quality (Default), CQM - UHD-BD source detected. - Decoding/Frame serving: NVENCC - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [22:47:06] PHASE ONE, Encoding - [22:47:06] Processing: VID_00009 (1 of 3) - [22:47:06] Extracting A/V streams [VID_00009] - [22:47:11] Reencoding video [VID_00009] - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - [22:47:21] Processing: VID_00007 (2 of 3) - [22:47:21] Extracting A/V streams [VID_00007] - [22:47:26] Reencoding video [VID_00007] - Track 4352 (min): Keeping original audio - [22:47:36] Processing: VID_00005 (3 of 3) - [22:47:36] Extracting A/V streams [VID_00005] - [22:59:17] Reencoding video [VID_00005] - Analyzing 1.00 [1.00] - Track 4352 (jpn): Keeping original audio - Track 4353 (eng): Keeping original audio [23:40:50]PHASE ONE complete [23:40:50]PHASE TWO - Rebuild Started - [23:40:50] Rebuilding BD file Structure [23:40:55] - Encode and Rebuild complete [23:40:55] Writing BD structure to ISO file - ImgBurn completed successfully [23:51:34] JOB: GOJIRA_AKA_GODZILLA_1954_CRITERION_2160P_USA_UHD_BLU-RAY_HEVC_LPCM_1.0-HORROR finished. |
#32175 | Link | |
I'll have to look at the subtitle problem... probably an issue with the PID. The error you got (00070) was "permission denied". I'm guessing that for some reason the operating system thought a file BD-RB was trying to access was open or in use.
#32176 | Link | ||
#32179 | Link |
Failed in attempt to multiplex
Wondered if someone could help - attempting to backup Nosferatu (2024) and it's failing. It actually failed quite a few times during the process with error code "PredictAndEncode() 00075 2809" - I've tried restarting from scratch, but had the same outcome. I then tried resuming from the previous job each time it failed, which felt like it was working; it eventually got up to the 100% but failed to rebuild with error code "TSMUXER ERR: 0xFFFFFFFE - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta" It's one of those movies/discs that has multiple parts, rather than just one m2ts file - not sure if this is the issue, but I've not had this problem before. Log is below - any help would be greatly appreciated; ---------------------- - Input BD size: 28.23 GB - Approximate total content: [02:12:35.697] - Windows Version: 6.2 [9200] - Quality: High Quality (Default), 1-Pass VBR - Audio Settings: AC3=1 DTS=0 HD=0 Kbs=640 [23:35:58] PHASE ONE, Encoding - [23:35:58] Processing: VID_00820 (1 of 16) - [23:35:58] Extracting A/V streams [VID_00820] - [23:36:14] Reencoding video [VID_00820] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 25,822 frames - Bitrate: 10,366 Kbs - [23:49:23] Video Encode complete - Track 4352 (eng): Reencoding audio to AC3... - Track 4353 (eng): Reencoding audio to AC3... - Track 4354 (eng): Reencoding audio to AC3... - [23:50:35] Processing: VID_00810 (2 of 16) - [23:50:35] Extracting A/V streams [VID_00810] - [23:50:40] Reencoding video [VID_00810] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,269 frames - Bitrate: 10,306 Kbs - [23:50:40] Reencoding: VID_00810, Pass 1 of 1 - [23:51:52] Video Encode complete - [23:51:52] Processing: VID_00822 (3 of 16) - [23:51:52] Extracting A/V streams [VID_00822] - [23:51:56] Reencoding video [VID_00822] - Source Video: MPEG-4 (AVC), 1920x1080 - Bitrate: 10,560 Kbs - [23:54:11] Video Encode complete - [23:54:11] Extracting A/V streams [VID_00811] - [23:54:15] Reencoding video [VID_00811] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 649 frames - Bitrate: 10,237 Kbs - [23:54:15] Reencoding: VID_00811, Pass 1 of 1 - [23:54:36] Video Encode complete - [23:54:36] Processing: VID_00823 (5 of 16) - [23:54:36] Extracting A/V streams [VID_00823] - [23:54:42] Reencoding video [VID_00823] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 12,753 frames - [23:54:42] Reencoding: VID_00823, Pass 1 of 1 - [00:02:02] Video Encode complete - [00:02:02] Extracting A/V streams [VID_00812] - [00:02:06] Reencoding video [VID_00812] - Source Video: MPEG-4 (AVC), 1920x1080 - Bitrate: 10,233 Kbs - [00:03:24] Video Encode complete - [00:03:24] Processing: VID_00824 (7 of 16) - [00:03:24] Extracting A/V streams [VID_00824] - [00:03:34] Reencoding video [VID_00824] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 53,912 frames - Bitrate: 10,528 Kbs - [00:03:34] Reencoding: VID_00824, Pass 1 of 1 - [00:34:31] Video Encode complete - [00:34:31] Extracting A/V streams [VID_00813] - [00:34:36] Reencoding video [VID_00813] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,720 frames - [00:34:36] Reencoding: VID_00813, Pass 1 of 1 - [00:35:31] Video Encode complete - [00:35:31] Extracting A/V streams [VID_00826] - [00:35:36] Reencoding video [VID_00826] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 14,018 frames - Bitrate: 10,425 Kbs - [00:35:36] Reencoding: VID_00826, Pass 1 of 1 - [00:43:27] Video Encode complete - [00:43:27] Processing: VID_00814 (10 of 16) - [00:43:31] Reencoding video [VID_00814] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 766 frames - [00:43:31] Reencoding: VID_00814, Pass 1 of 1 - [00:43:54] Video Encode complete - [00:43:54] Processing: VID_00827 (11 of 16) - [00:44:00] Reencoding video [VID_00827] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 19,203 frames - Bitrate: 10,298 Kbs - [00:44:00] Reencoding: VID_00827, Pass 1 of 1 - [00:54:43] Video Encode complete - [00:54:43] PredictAndEncode() 00075 2809 ---------------------- - Input BD size: 28.23 GB - Windows Version: 6.2 [9200] - Quality: High Quality (Default), 1-Pass VBR - Audio Settings: AC3=1 DTS=0 HD=0 Kbs=640 - Resuming from previously started job. [09:23:23] PHASE ONE, Encoding - [09:23:23] Processing: VID_00822 (3 of 16) - [09:23:23] Extracting A/V streams [VID_00822] - [09:23:27] Reencoding video [VID_00822] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,758 frames - Bitrate: 10,560 Kbs - [09:23:27] Reencoding: VID_00822, Pass 1 of 1 - [09:25:31] Video Encode complete - [09:25:31] Extracting A/V streams [VID_00811] - [09:25:35] Reencoding video [VID_00811] - Source Video: MPEG-4 (AVC), 1920x1080 - Bitrate: 10,237 Kbs - [09:25:56] Video Encode complete - [09:25:56] Processing: VID_00823 (5 of 16) - [09:25:56] Extracting A/V streams [VID_00823] - [09:26:01] Reencoding video [VID_00823] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 12,753 frames - Bitrate: 10,461 Kbs - [09:26:02] Reencoding: VID_00823, Pass 1 of 1 - [09:33:21] Video Encode complete - [09:33:21] Extracting A/V streams [VID_00812] - [09:33:25] Reencoding video [VID_00812] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,070 frames - Bitrate: 10,233 Kbs - [09:33:25] Reencoding: VID_00812, Pass 1 of 1 - [09:34:43] Video Encode complete - [09:34:43] PredictAndEncode() 00075 2809 ---------------------- - Input BD size: 28.23 GB - Target BD size: 11.72 GB - MOVIE-ONLY mode enabled - Decoding/Frame serving: DirectShow - Resuming from previously started job. [09:35:24] PHASE ONE, Encoding - [09:35:24] Processing: VID_00812 (6 of 16) - [09:35:24] Extracting A/V streams [VID_00812] - [09:35:27] Reencoding video [VID_00812] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,070 frames - Bitrate: 10,233 Kbs - [09:35:28] Reencoding: VID_00812, Pass 1 of 1 - [09:36:37] Video Encode complete - [09:36:37] PredictAndEncode() 00075 2809 ---------------------- - Input BD size: 28.23 GB - Target BD size: 11.72 GB - MOVIE-ONLY mode enabled - Decoding/Frame serving: DirectShow - Resuming from previously started job. [09:37:04] PHASE ONE, Encoding - [09:37:05] Processing: VID_00824 (7 of 16) - [09:37:05] Extracting A/V streams [VID_00824] - [09:37:14] Reencoding video [VID_00824] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 53,912 frames - Bitrate: 10,528 Kbs - [09:37:14] Reencoding: VID_00824, Pass 1 of 1 - [10:08:08] Video Encode complete - [10:08:08] Processing: VID_00813 (8 of 16) - [10:08:08] Extracting A/V streams [VID_00813] - [10:08:12] Reencoding video [VID_00813] - Source Video: MPEG-4 (AVC), 1920x1080 - Bitrate: 10,233 Kbs - [10:09:07] Video Encode complete - [10:09:07] PredictAndEncode() 00075 2809 ---------------------- [10:23:35] Source: NOSFERATU_UPB1_00000 - Approximate total content: [02:12:35.697] - Windows Version: 6.2 [9200] - Quality: High Quality (Default), 1-Pass VBR - Audio Settings: AC3=1 DTS=0 HD=0 Kbs=640 - Resuming from previously started job. [10:23:39] PHASE ONE, Encoding - [10:23:39] Processing: VID_00813 (8 of 16) - [10:23:43] Reencoding video [VID_00813] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,720 frames - Bitrate: 10,233 Kbs - [10:23:43] Reencoding: VID_00813, Pass 1 of 1 - [10:24:28] Video Encode complete - [10:24:28] PredictAndEncode() 00075 2809 ---------------------- [10:42:52] Source: NOSFERATU_UPB1_00000 - Approximate total content: [02:12:35.697] - Windows Version: 6.2 [9200] - Quality: High Quality (Default), 1-Pass VBR - Audio Settings: AC3=1 DTS=0 HD=0 Kbs=640 - Resuming from previously started job. [10:42:54] PHASE ONE, Encoding - [10:42:54] Processing: VID_00826 (9 of 16) - [10:42:54] Extracting A/V streams [VID_00826] - [10:42:59] Reencoding video [VID_00826] - Source Video: MPEG-4 (AVC), 1920x1080 - Bitrate: 10,425 Kbs - [10:50:42] Video Encode complete - [10:50:42] Processing: VID_00814 (10 of 16) - [10:50:42] Extracting A/V streams [VID_00814] - [10:50:45] Reencoding video [VID_00814] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 766 frames - Bitrate: 10,209 Kbs - [10:50:45] Reencoding: VID_00814, Pass 1 of 1 - [10:51:08] Video Encode complete - [10:51:08] Extracting A/V streams [VID_00827] - [10:51:14] Reencoding video [VID_00827] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 19,203 frames - Bitrate: 10,298 Kbs - [10:51:14] Reencoding: VID_00827, Pass 1 of 1 - [11:01:58] Video Encode complete - [11:01:58] Processing: VID_00815 (12 of 16) - [11:01:58] Extracting A/V streams [VID_00815] - [11:02:02] Reencoding video [VID_00815] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 4,041 frames - Bitrate: 10,201 Kbs - [11:02:02] Reencoding: VID_00815, Pass 1 of 1 - [11:04:18] Video Encode complete - [11:04:18] PredictAndEncode() 00075 2809 ---------------------- - Input BD size: 28.23 GB - Target BD size: 11.72 GB - MOVIE-ONLY mode enabled - Decoding/Frame serving: DirectShow - Resuming from previously started job. [11:04:34] PHASE ONE, Encoding - [11:04:34] Processing: VID_00828 (13 of 16) - [11:04:34] Extracting A/V streams [VID_00828] - [11:04:39] Reencoding video [VID_00828] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 9,387 frames - [11:04:39] Reencoding: VID_00828, Pass 1 of 1 - [11:09:51] Video Encode complete - [11:09:51] Extracting A/V streams [VID_00816] - [11:09:55] Reencoding video [VID_00816] - Source Video: MPEG-4 (AVC), 1920x1080 - Bitrate: 10,271 Kbs - [11:10:31] Video Encode complete - [11:10:31] Processing: VID_00829 (15 of 16) - [11:10:31] Extracting A/V streams [VID_00829] - [11:10:38] Reencoding video [VID_00829] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 29,418 frames - Bitrate: 10,436 Kbs - [11:10:38] Reencoding: VID_00829, Pass 1 of 1 - [11:27:08] Video Encode complete - [11:27:08] Processing: VID_00817 (16 of 16) - [11:27:08] Extracting A/V streams [VID_00817] - [11:27:13] Reencoding video [VID_00817] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 9,892 frames - Bitrate: 10,151 Kbs - [11:27:13] Reencoding: VID_00817, Pass 1 of 1 - [11:29:09] Video Encode complete [11:29:09]PHASE ONE complete [11:29:09]PHASE TWO - Rebuild Started - [11:29:09] Rebuilding BD file Structure - TSMUXER ERR: 0xFFFFFFFE - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta [11:29:13] - Failed to REBUILD ---------------------- [11:29:53] Source: NOSFERATU_UPB1_00000 - Approximate total content: [02:12:35.697] - Windows Version: 6.2 [9200] - Quality: High Quality (Default), 1-Pass VBR - Audio Settings: AC3=1 DTS=0 HD=0 Kbs=640 - Resuming from previously started job. [11:29:55] PHASE ONE, Encoding [11:29:55]PHASE ONE complete - [11:29:55] Rebuilding BD file Structure - TSMUXER ERR: 0xFFFFFFFE - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta |
#32180 | Link |
That error code (75) means "Path/File access error". You may want to check the path to your working or source folder(s) and see if it has some unusual characters, or if it is exceptionally long.
| Thread Tools | |
| Display Modes | |
