#481 | Link | |
Edit: ok, so after lots of trials and errors, I come to the conclusion that there seems to be no TS descriptor for PGS. And if we put back the HDMV registration descriptor to read PGS in TS would break DV compatibility with standalone players. Same for AC3/TrueHD. So you can't have everything: PGS and interleaved AC3/TrueHD are HDMV streams and must be muxed in m2ts. And there is no TS or HDMV descriptor for TrueHD (without AC3), so no way to include it in tsMuxer. Last edited by a5180007; 1st March 2020 at 23:01. |
#482 | Link |
What is the issue with PGS and .TS? I was able to show PGS subs on the Sony X700 without issue from the 3/1 nightly build. Of course, my LG C8 doesn't play the generated .TS file, but I don't care as I won't have lossless TrueHD even if it did.
Thank you for your work, by the way. You solved what I was trying to do for over a year - DV and TrueHD Atmos from file playback. |
#483 | Link | |
Edit : cf. https://en.wikipedia.org/wiki/Progra..._specific_data) The issue is that the PGS in TS don't play anymore in ffmpeg players (VLC, HPC, MPlayer...) without the HDMV descriptors. And if I reintroduce the HDMV descriptors (which is non-standard for TS), DV won't work anymore in the standalone players. Which means that for PC we have to use m2ts for PGS subtitles. Last edited by a5180007; 2nd March 2020 at 06:24. |
#484 | Link | |
Life's clearer in 4K UHD
#485 | Link | |
#486 | Link |
@Stereodude PGS and AC3/trueHD are covered by the Blu-ray format specifications. But in TS, yes it is a grey area not covered by any standard (H.222.0, ATSC, DVB...) So I guess If you ask guys at ffmpeg nobody will want to implement it.
#487 | Link |
So, if I get this right...
What some people would like TSmuxer to do is have the ability to mux: HEVC video with Dolby Vision along with Dolby TrueHD audio and SUP subtitles into the .TS [188 byte packet] container, instead of into the .m2ts [192 byte packet] container? If so... What's the point of doing this? Cheers
#488 | Link | |
Good question... |
#489 | Link |
Isn't it to have a file with 2 layer Dolby Vision with Atmos (True-HD) audio that's fully playable on the Sony x700 UHD blu-ray player (and others?) enabling DV UHD BD "rips"?
Isn't the Oppo (and clones) the only consumer device capable of playing such content with proper DV 2 layer decoding and lossless Atmos (prior to making such .TS files for the Sony)? Last edited by Stereodude; 2nd March 2020 at 19:39. |
#490 | Link | |
Okay then, so: HEVC video with 2-layer Dolby Vision along with Dolby TrueHD audio and SUP subtitles within the .TS [188 byte packet] container... I haven't tried doing this ![]()
#491 | Link | |
I think imhh11 said it worked in a M2TS also. Last edited by Stereodude; 2nd March 2020 at 20:34. |
#492 | Link |
I guess we could do with confirmation about who's players support 'HEVC video with 2-layer Dolby Vision.M2TS' file playback. And who's players only support 'HEVC video with 2-layer Dolby Vision.TS' file playback!
#493 | Link | |
#495 | Link | |
Apart from the 2-layer Dolby Vision HEVC video stream, what other streams are in your .ts file back-ups?
#496 | Link | |
#497 | Link | |
https://onedrive.live.com/?authkey=%...&action=locate but TS or m2ts, i dont really care. As long i can watch DV+ atmos via usb or my network, i'm happy...And right now I'm very happy ![]() Code:
Complete name : D:\test.split.1.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 920 MiB Duration : 2 min 0 s Overall bit rate mode : Variable Overall bit rate : 64.0 Mb/s Maximum Overall bit rate : 35.5 Mb/s Video #1 ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible Codec ID : 36 Duration : 2 min 0 s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 745 cd/m2 Maximum Frame-Average Light Level : 47 cd/m2 Video #2 ID : 4117 (0x1015) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible Codec ID : 36 Duration : 2 min 0 s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Last edited by imhh11; 2nd March 2020 at 23:17. |
#498 | Link |
[QUOTE=imhh11;1902629]only this test build can make DV m2ts. And yes, it plays on the x700
https://onedrive.live.com/?authkey=%...&action=locate but TS or m2ts, i dont really care. As long i can watch DV+ atmos via usb or my network, i'm happy...And right now I'm very happy ![]() Excellent, I'll test this version too in the morning. I'm very happy that I can finally play DV rips on my X700 as well. |
#499 | Link |
Yes, .ts or .m2ts on the sony x700 they have the problem exposed in post 470 and 471, that is very annoying.
Also could someone explain why mediainfo reports that both videotracks are dolby vision? mediainfo.txt |
#500 | Link | |
@a5180007 Could it be possible to do a test build that would put DV descriptor only on the DV layer just like the mp4muxer. maybe that's the reason why it doesn't work on my LG C8? Thank's mp4muxer: Code:
Complete name : G:\4k\Terminator.Dark.Fate.2019.DV.mp4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 (isom/mp42/dby1) File size : 57.0 GiB Duration : 2 h 8 min Overall bit rate : 63.7 Mb/s Encoded date : UTC 2020-01-18 23:49:16 Tagged date : UTC 2020-01-18 23:49:16 Video #1 ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : hev1 Codec ID/Info : High Efficiency Video Coding Duration : 2 h 8 min Bit rate : 48.7 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.245 Stream size : 43.6 GiB (76%) Default : No Encoded date : UTC 2020-01-18 23:00:19 Tagged date : UTC 2020-01-18 23:51:19 Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 1000 cd/m2 Maximum Frame-Average Light Level : 446 cd/m2 Codec configuration box : hvcC Video #2 ID : 2 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible Codec ID : dvhe Codec ID/Info : High Efficiency Video Coding with Dolby Vision Duration : 2 h 8 min Bit rate : 5 130 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.103 Stream size : 4.59 GiB (8%) Default : No Encoded date : UTC 2020-01-18 23:00:19 Tagged date : UTC 2020-01-18 23:51:19 Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Codec configuration box : hvcC+dvcC tsMuxer: Code:
Complete name : I:\Gemini.Man.2019.DV.60FPS.ts Format : MPEG-TS File size : 75.6 GiB Duration : 1 h 57 min Overall bit rate mode : Variable Overall bit rate : 92.5 Mb/s Maximum Overall bit rate : 35.5 Mb/s Video #1 ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL / SMPTE ST 2086, HDR10 compatible Codec ID : 36 Duration : 1 h 57 min Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 59.940 (60000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 5180 cd/m2 Maximum Frame-Average Light Level : 1577 cd/m2 Video #2 ID : 4117 (0x1015) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible Codec ID : 36 Duration : 1 h 57 min Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 59.940 (60000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2 Last edited by imhh11; 3rd March 2020 at 01:10. |
