Old 15th January 2010, 00:04   #801  |  Link
quantum5uicid3
He's using the old profiles, the "insane" profile now is just crf 17, not a 2pass.
There have been many changes to x264 since Sharktooth did those profiles and their use is strongly discouraged. The megui profiles as they exist now are more or less simple device presets with crf going from 17-23 in 1.5 increments and a 2 pass for each device. 2pass is only needed now when you need an exact target bitrate.
So on all presets you're encouraged to change the speed to your preference and use the bitrate calculator to find bitrate. Then just save them as you like them.
quantum5uicid3 is offline   Reply With Quote
Old 15th January 2010, 08:59   #802  |  Link
easy2Bcheesy
easy2Bcheesy's Avatar
So, how do I change the new Insane preset to give me the same quality as the old one? I realise that its use may be "discouraged", but the bottom line is that I am encoding 720p on an extremely tight bitrate. The old preset took a long time to encode but the results were worth it. The new preset doesn't give me the quality I need.
I'd be happy to a straight A to B comparison, but right now I can't, since I don't have the old preset any more!
easy2Bcheesy is offline   Reply With Quote
Old 15th January 2010, 09:28   #803  |  Link
lucamark
Gigibop!!!
Try with 1pass crf=17 preset= more slower as you can..
lucamark is offline   Reply With Quote
Old 15th January 2010, 10:12   #804  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@easy2Bcheesy
import my attempt to duplicate it x264_dp_ iNSANE2.xml
let me know how the project comes out i just might duplicate all of them to the new switches
MuLTiTaSK is offline   Reply With Quote
Old 15th January 2010, 21:28   #805  |  Link
easy2Bcheesy
That is an enormous improvement on the new Insane - many thanks
Old 15th January 2010, 22:05   #806  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@easy2Bcheesy
your welcome i'am glad you liked it
alot has changed with x264 since ST created those older presets the lastest presets are mainly using x264 defaults with specific tweaks for devices rather then quality reason you noticed the quality loss
Old 16th January 2010, 21:30   #807  |  Link
carlo_0000
hello
i update megui today and the profils
but
it that normal that 1 st pass is 2 times slower than before ?
i olways use best quality insane dxva profils
and when i start the queud jobs it take some long time before cpu is used (i see only disk acces)
i olso notice that x264 use more that 1 gigas of the pagefile.sys and slowdown the computer performance
with the old megui the 1st pass starded immediatly (using the cpu)
carlo_0000 is offline   Reply With Quote
Old 17th January 2010, 02:38   #808  |  Link
QuadraQ
QuadraQ's Avatar
Just updated megui and got the new profiles (they look good). I've used the AVCHD in the past, and it was a two pass encode. The new one "AVCHD (DVD5/9) - High Quality" seems to be running as a one pass. Are you using some new magic in x264 to accomplish this?
Another question: The unrestricted profiles and the DXVA profiles seem to have been consolidated. Does this mean that I can take advantage of my DXVA compatible system (for greater encoding speed) while still creating an unrestricted x264 MKV?
QuadraQ is offline   Reply With Quote
Old 17th January 2010, 09:09   #809  |  Link
nurbs
Depends on the hardware you have. If you want to be 100% sure it plays you should restrict it to level 4.1 and set the appropriate vbv parameters. As long as you don't manually enter the number of reference frames the --level setting will automatically restrict the number.
nurbs is offline   Reply With Quote
Old 17th January 2010, 09:31   #810  |  Link
rtjnyoface
Constantly learning
rtjnyoface's Avatar
You could use mediainfo on some of the files you used your preferred configuration on and it will at least give you some ideas as to what new preset could be considered the same. Mediainfo will give you a couple of things such as the # of reference frames, the level of subpixel refinement, trellis use, I'm not sure what else ATM.
So increase the amount of analysis, reference frames, motion estimation and such.
You might have to if you aren't able to have a final product similar to what you had prior to the changes.
Hope it helps somewhat. (Ha, put it on placebo ).
rtjnyoface is offline   Reply With Quote
Old 17th January 2010, 13:43   #811  |  Link
Poutnik
Useless idea generator
Poutnik's Avatar
I have found than in my MeGUI "Unrestricted (DXVA)" X264 profiles is everywhere Trellis disabled.
I am confused - either something is wrong either I do not understand it well.
I always thought Trellis does not affect decoding, at least not to corrupt HW compatibilty.
I have also always thought at least Trellis=1 is needed for SubME 6+ for RD optimization.
Vista64 Premium SP2 / C2D E4700 2.6GHz/ 6GB RAM/ Intel GMA 3100 / DTV Leadtek DONGLE GOLD USB2 /
focused to DVB-T MPEG2 PS capture -> ProjectX -> M2V/MP2 -> MeGUI/AVS -> MP4[AVC/AAC]
Poutnik is offline   Reply With Quote
Old 17th January 2010, 15:28   #812  |  Link
ZEXEL
ZEXEL's Avatar
I've been update to new MegUI version & find all new preset profile also I really happy with that, but could you tell me where is the same/better quality picture profile for "x264: Standalone-HD-DVD" since it gone... cheers...
ZEXEL is offline   Reply With Quote
Old 21st January 2010, 22:15   #813  |  Link
ShadowVlican
ShadowVlican's Avatar
hm.. i guess someone should edit the first post of this thread to notify newcomers that the profiles are now obsolete
and perhaps remove them from MeGui altogether
ShadowVlican is offline   Reply With Quote
Old 22nd January 2010, 03:52   #814  |  Link
iko417
remove them, never used them
Hardware Reviews
iko417 is offline   Reply With Quote
Old 22nd January 2010, 19:34   #815  |  Link
Wikke
I just updated to new presets in Megui. I have always used Standalone AVCHD presets and I was satisfied with the results. Normal speed for:
720p encoding was first pass 115 FPS and second pass 85 FPS. Needed time for encoding the whole film was 1 hour.
1080p encoding was first pass 55 FPS and second pass 45 FPS. Encoding time for the whole film was 2 hours.
Now with new updated presets the whole encoding is taking much more time to finish the job.
I am now encoding 1080p material with Standalone AVCHD presets and the framerate for first pass is only 15 FPS!!! I guess the second pass will be only 5 FPS.
Are the others facing the same problem, or is there something wrong with my updates?
Is the quality with new presets really so much better that it is taking 3 times more time to finish the job?
Wikke is offline   Reply With Quote
Old 24th January 2010, 23:49   #816  |  Link
blsbball
Anyone else notice any downgrade in quality from the older unrestricted const quality insane x264 and the new dxva unrestricted? I feel like the older profile, although it produced a larger file, produced much better results.
blsbball is offline   Reply With Quote
Old 26th January 2010, 07:51   #817  |  Link
Poutnik
Poutnik's Avatar
Reformulated question - is Trellis safe to use for DXVA ( and evantually HW players ?
Old 27th January 2010, 07:46   #818  |  Link
J-Wo
I'm trying out these presets with MeGUI to convert my DVD rips to MKV for better playback compatibility with my WDTV Live. I want to preserve quality so I'm thinking of using the DXVA-SD-Extra Quality preset. How does this differ from Standalone-PS3-Xbox360? I know the WDTV Live is less restrictive than PS3 or Xbox360, so maybe I should try Unrestricted 2pass Extra Quality? I'm not sure what file size/bitrate I should aim for but will ~2000 kbps (2cd file size) yield good results? Thanks.
J-Wo is offline   Reply With Quote
Old 27th January 2010, 08:18   #819  |  Link
nurbs
Trellis is purely an analysis option and therefore doesn't influence hardware players.
Old 29th January 2010, 00:58   #820  |  Link
Beak
Hi. I hope one of the devs will confirm or assist the slowdown in encoding speeds. I am crawling now at about 2 frames per second with the X264 Unrestricted 2 pass Extra Quality Preset.
The commandline reads
program --profile high --preset fast --tune film --pass 2 --bitrate 12228 --stats ".stats" --thread-input --b-adapt 2 --ref 3 --rc-lookahead 40 --me umh --direct auto --subme 7 --partitions all --trellis 2 --output "output" "input"
I would prefer to have the speed back as it looked quite good to me before.
Can anyone tell me what the arguments used to be for this preset?
Is there anyplace one can download the previous version of Megui and its updates?
Beak is offline   Reply With Quote
megui, x264 presets
