4th February 2013, 12:09 | #981 | Link | |
i.e. CRF 16 will be better quality than CRF 23 If you hover over the Quality box in the config window you will see a tooltip with a very good explanation. Unfortunately you cannot copy/paste from a tooltip otheriwse I'd repeat it here. |
4th February 2013, 12:43 | #982 | Link | |
But you can easily quote from megui\Data\ContextHelp.xml:
28th March 2013, 21:34 | #983 | Link |
For some reason the link sems to be dead for me. I know the archive is outdated for settings for x264 but i would still like it if possible.
EDIT: never mind the mirror worked Last edited by TheProfosist; 28th March 2013 at 21:46. |
15th October 2013, 08:00 | #986 | Link |
Read the last reply by Zathor above your post again.
Use the basic "Preset" and "Tuning" options if you know less about the relations between the advanced x264 options that the developers of x264. |
16th October 2013, 07:46 | #988 | Link |
Understanding some of the advanced options in x264 may require having read and understood the MPEG4 Part 1, 2, and 10 specifications, as well as general video analysis and compression techniques. Most of that is technical stuff too heavy for the average user. Therefore, the x264 developers spent a lot of efforts into balancing the relations between presets and tunings to be useful in most cases. And in general you can trust the rule: Nothing is better than "enough" bitrate.
22nd October 2013, 17:53 | #989 | Link | |
Do you mean that is enough for average user to encode in settings such as presets and tunings, high bitrate? |
23rd October 2013, 07:56 | #990 | Link |
Yes. The x264 developers put severe efforts into condensing the complex relations between the many detail options to so few convenient and intuitive meta-options that average users can most probably get acceptable-to-great results with
21st March 2014, 19:53 | #994 | Link |
And as an additional information:
Every setting which has changed internally in the last years will not be applied at all when importing these old presets. So you will definitively end with something between the original preset and the recent MeGUI default values as a lot has been changed internally over those years. Last edited by Zathor; 21st March 2014 at 21:03. |
21st March 2014, 20:59 | #995 | Link |
NY Frame of Mind
I didn't realize that !
So, in the "Input" screen what do you enter in the Encoder Settings dialog box (where the presets are/were displayed)? If I delete all the x264 preset options/profiles, then x264: "Scratchpad" remains. Is that what it should be?
"Talk to me Goose" Last edited by rapscallion; 21st March 2014 at 21:09. |
21st March 2014, 21:08 | #996 | Link |
It is up to you. But I would not import those old presets and instead create a few new ones depending on what you need / encode for.
I have created a few presets for my encodings like several Bluray presets and also a few WDTV ones. All of my presets have crf (~18) & very slow setting & no/film tuning. At the end you can say I change only settings on the first page and do not bother with the other settings. |
21st March 2014, 21:56 | #997 | Link |
NY Frame of Mind
The only one I've been using for a long time is the x264:Blu-ray 1080p/720p. On build #2487
First page (show advanced settings) I select "Automated 2 pass", "Target Playback Device: Bluray", "Tuning": Film "Bitrate": whatever I get in the bitrate calculator for the particular BD I'm re-encoding (I usually reduce a full BD-50 down to BD-25, film only) And, like you, "Preset": slow If I select "scratchpad", and apply the same setting as above, the command line is virtually identical. BTW, I wouldn't know the first thing on creating a preset. I don't see any option in any of the "Advanced Settings" for selecting CRF 18. But, then again, I'm using VBR so Constant Rate Factor wouldn't apply, I believe? Edit: I have been happy with the results and always seem to get a result almost identical/transparent to the original BD. Custom Command line on the Misc page: Code:
--level 4.1 --bframes 3 --ref 4 --slices 4 --aud -nal-hrd vbr --b-pyramid strict --keyint 24 --min-keyint 2 -vbv-bufsize 30000 --vbv-maxrate 40000 --weightp 0 -colorprim "bt709" --transfer "bt709" --colormatrix "bt709"
"Talk to me Goose" Last edited by rapscallion; 22nd March 2014 at 21:26. |
megui, x264 presets |
