Old 8th July 2023, 18:49   #21  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
also mkvtoolnix updated to 10.0 (last ver. that work with xp from what I read in reddit)
pssst
https://msfn.org/board/topic/177627-...vista-version/
Old 8th July 2023, 19:53   #22  |  Link
real.finder
Originally Posted by FranceBB View Post
thanks, here as "new2" https://sourceforge.net/projects/aud...w2.7z/download
but it's seems not work with newer windows, anyway if anyone want to use last mkvtoolnix he can delete both mkvmerge and mkvextract and it should use the mkvtoolnix that installed in the system, or simply replace mkvmerge and mkvextract with newer one
See My Avisynth Stuff
Old 8th July 2023, 20:01   #23  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Uhmmmm 2018, it's been a minute... but I actually checked and now I remember. I'm so sorry about that.
Yes, that version will only work on Windows XP x86 as I shipped it together with the compatibility layer we were working on with Samuel back at the beginning of One Core API.
That was way before One Core API became a standalone installer you could install in your system like a normal Service Pack, which means that while it made it possible to use what we were porting to XP, it also broke things for literally any other version of Windows.
You might wanna revert...
chapters, helper tool, splitter, text subtitles, vfr
