4th February 2022, 19:05 | #81 | Link | |
OverNet: Lightweight multi-scale super-resolution with overscaling network https://arxiv.org/abs/2008.02382 Unfortunally their GH seems empty: https://github.com/pbehjatii/OverNet |
5th February 2022, 11:58 | #82 | Link | |
thanx for mentioning it,m looking good
there is hope, GITHUB says: Quote:
15th February 2022, 23:46 | #83 | Link |
I requested VRT: A Video Restoration Transformer
https://github.com/JingyunLiang/VRT https://github.com/HolyWu/vs-basicvsrpp/issues/21 |
25th February 2022, 18:55 | #84 | Link |
Here's another kind of enhancer that claims to make HDR from SDR:
https://github.com/nothinglo/Deep-Photo-Enhancer Results on video: https://www.youtube.com/watch?v=d7OXb2sqoec Pytorch implementation: https://github.com/mtics/deep-photo-enhancer Last edited by PatchWorKs; 25th February 2022 at 19:34. |
19th March 2022, 20:33 | #85 | Link |
HolyWu posted an update for vs-dpir. I'm not sure what provider uses what onxruntime.
Okay, got that cleared up, see: https://github.com/HolyWu/vs-dpir/issues/20 CUDA: encoded 429 frames, 8.83 fps, 1117.06 kb/s DIRECTML: encoded 429 frames, 6.03 fps, 1117.74 kb/s CPU: encoded 429 frames, 0.49 fps, 1116.08 kb/s (can't test CUDA TensorRT since I only got an old Geforce GTX 1070ti) -> seems that onnxruntime-gpu is the way to go for CUDA cards. Last edited by Selur; 20th March 2022 at 10:31. |
20th March 2022, 16:34 | #86 | Link | |
26th March 2022, 12:40 | #87 | Link |
Did anyone get vs-dpir installed when using Vapoursynth R58-RC1? (https://github.com/HolyWu/vs-dpir/issues/22)
vs-basicvsrpp also doesn't work since mmcv_full is meant for Python 3.9 which isn't supported in Vapoursynth R58 (only 3.8 and 3.10) (https://github.com/HolyWu/vs-basicvsrpp/issues/23) Similar for vs-rife and vs-realesrgan. Cu Selur Last edited by Selur; 26th March 2022 at 13:06. |
26th March 2022, 16:27 | #88 | Link |
Thanks to HolyWu I got vs-basicvsrpp working using:
python -m pip install mmcv-full -f https://download.openmmlab.com/mmcv/dist/cu113/torch1.11/index.html python -m pip install tqdm python -m pip install opencv-python python -m pip install --upgrade vsbasicvsrpp python -m vsbasicvsrpp Cu Selur |
27th March 2022, 14:51 | #89 | Link | |
30th March 2022, 15:25 | #90 | Link | |
31st March 2022, 18:34 | #91 | Link |
How about (new ?) VRT - A Video Restoration Transformer ?
https://github.com/JingyunLiang/VRT Tests would be great. |
3rd April 2022, 13:17 | #92 | Link |
Maybe vs-mlrt (https://github.com/AmusementClub/vs-mlrt) will add support for it, based onhttps://docs.microsoft.com/en-us/windows/ai/windows-ml/tutorials/pytorch-convert-model conversion from pth to onnx models might be possible.
10th July 2022, 18:52 | #95 | Link |
The cult of personality
is there any good use of this filter on high quality anime encode releases?
I mean if sharpness and detail preservation are wanted, then descaling is the way to go if can be done. Plus some high quality denoisers and careful masked debanding can yield best results. what can this filter offer? |
12th July 2022, 04:18 | #96 | Link |
Assuming you are referring to BasicVSR++, it's meant for restoration so using it on a 'high quality' sounds like wanting to give a new car to a restaurator,...
As a side note: There are tons of Anime trained models (https://upscale.wiki/wiki/Model_Database) for VSGAN which might be more suited, detail preservation totally depends on the model used. Using ml stuff on high resolution content is really slow with current hardware, so if high quality also means high source resolution be prepared to wait. Cu Selur |
6th September 2022, 04:29 | #97 | Link |
I've modified __init__.py in the vsbasicvsrpp folder to include the NTIRE 4x VSR model if anyone is interested
https://www.mediafire.com/file/k0bba...+VSR).zip/file https://github.com/open-mmlab/mmedit...icvsr_plusplus Extract __init__.py from the zip archive ,and download the model and place in same vsbasicvsrpp directory https://download.openmmlab.com/mmedi...1-1ff35292.pth Code:
model: Model to use. 0 = REDS 1 = Vimeo-90K (BI) 2 = Vimeo-90K (BD) 3 = NTIRE 2021 Video Super-Resolution 4 = NTIRE 2021 Quality enhancement of heavily compressed videos Challenge - Track 1 5 = NTIRE 2021 Quality enhancement of heavily compressed videos Challenge - Track 2 6 = NTIRE 2021 Quality enhancement of heavily compressed videos Challenge - Track 3 The model uses mid_channels 128 and num_blocks 25 (instead of 64 and 7), as written in the pth name, and in the py file, so I modified those entries and the other relevant ones https://github.com/open-mmlab/mmedit...k_ntire_vsr.py It seems to work ok, and results are similar to REDS model, maybe slightly better or on some sources. The py says it was trained on REDS data set with spynet_20210409-c6c1bd09.pth pretrain |
10th September 2022, 08:45 | #99 | Link |
btw. HolyWu just release vs-dpir-ncnn version
python -m pip install -U vsdpir_ncnn python -m pip install --upgrade https://github.com/HolyWu/ncnn/releases/download/1.0.20220910/ncnn-1.0.20220910-cp310-cp310-win_amd64.whl python -m vsdpir_ncnn Code:
from vsdpir_ncnn import dpir ret = dpir(clip) Code:
def dpir( clip: vs.VideoNode, strength: float | vs.VideoNode | None = None, task: str = 'denoise', tile_w: int = 0, tile_h: int = 0, tile_pad: int = 8, gpu_id: int | None = None, fp16: bool = True, ) -> vs.VideoNode: """ DPIR: Deep Plug-and-Play Image Restoration Parameters: clip: Clip to process. Only RGB and GRAY formats with float sample type of 32 bit depth are supported. strength: Strength for deblocking/denoising. Defaults to 50.0 for 'deblock', 5.0 for 'denoise'. Also accepts a GRAY8/GRAYS clip for varying strength. task: Task to perform. Must be 'deblock' or 'denoise'. tile_w, tile_h: Tile width and height, respectively. As too large images result in the out of GPU memory issue, so this tile option will first crop input images into tiles, and then process each of them. Finally, they will be merged into one image. 0 denotes for do not use tile. tile_pad: The pad size for each tile, to remove border artifacts. gpu_id: The GPU ID. fp16: Enable FP16 mode. """ If someone compares this to https://github.com/HolyWu/vs-dpir let us know whether there are some speed differences between the two. Thanks! On my Geforce GTX 1070ti on 640x352 content I get: vs-dpir: Code:
clip = DPIR(clip=clip, strength=5.000, task="denoise", provider=1, device_id=0, dual=True) Code:
clip = DPIR(clip=clip, strength=5.000, task="denoise", provider=1, device_id=0) vs-dpir-ncnn: Code:
clip = dpir(clip=clip, strength=5.000, task="denoise", gpu_id=0) So for me it's better to stick with normal vs-dpir, but I wonder whether this is true for folks with other cards. Cu Selur Last edited by Selur; 10th September 2022 at 09:11. |
11th September 2022, 11:24 | #100 | Link | |
update to vs-dpir-ncnn:
