#21501 | Link |
Major, I guess I figured I already posted about immortals audio track. Post 21482:
"(The postman) VC-1 streams, TRUE HD audio 640Kbps (IMMORTALS) AVC streams\ DTS-HD XLL 1509Kbps MA\Core" I suppose I should make every reference possible. That way everyone concerned, has a reference point ![]()
#21502 | Link | |
Passed Newbie Inquisition
![]() Sorry to be a pill about the details. Last edited by MajorEvent; 7th October 2014 at 21:36. |
#21503 | Link | |
I'll try to be more specific in the future. So as to not confuse, or leave things open for interpretation ![]()
#21504 | Link | |
#21509 | Link | |
![]() Join Date: Oct 2001
#21510 | Link | |
#21511 | Link | |
#21513 | Link |
This might be a dumb question but I feel I should ask.
For playback I use JRiver which has an earlier version of LAV. I also installed LAV 0.63 for Dolby Atmos decoding. Omegaman7 has MPC-HC, which has LAV in its install. Could this be the issue. Multiple versions of LAV on a system. |
#21515 | Link | |
#21516 | Link | |
This makes me think that in your cases whatever AVC decoder is there by default (before LAVFilters installation) with Win7/8 is being used rather than LAV... perhaps it isn't being overridden in your install. That might have something to do with the Win7 default settings -- which had to be manually set by BD-RB when using FFDSHOW -- maybe they need to be forced for LAV also??? Can you check and make sure AVC decoding is checked under formats in the video configuration? Last edited by jdobbs; 8th October 2014 at 01:28. |
#21517 | Link |
Could one of you out-of-sync guys look at your registry see what value you have set for these keys:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\DirectShow\Preferrred\{31435641-0000-0010-8000-00AA00389B71} HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\DirectShow\Preferred\{31435641-0000-0010-8000-00AA00389B71} This is the AVC preferred CODEC. Last edited by jdobbs; 8th October 2014 at 01:35. |
#21518 | Link |
Not to derail your LAVFilter discussions, but any idea why Alt Movie Only to MKV (1920x1080 intact Audio) backups are now taking longer than before?
On 09/05/14 Using v0.47.07 (beta) Source: 34255889_PRESTIGE_NA_00011 - Input BD size: 30.75 GB - Approximate total content: [02:10:29.822] Started at 13:44:44 ended at 15:46:17 (2hrs 2 min) On 09/30/14 using v0.47.07 (beta) Source: IMAX_HUBBLE_BD80_00100 - Input BD size: 9.67 GB - Approximate total content: [00:43:58.635] Started at 18:06:20 and completed at 18:56:15 (about 50 minutes) on 10/06/14 using v0.49.02 (beta) Source: IMAX_HUBBLE_BD80_00100 - Input BD size: 9.67 GB - Approximate total content: [00:43:58.635] Started at 11:27:14 and completed at 12:26:37 (about 59 minutes) Today, using v0.49.04 (beta) Source: THE_MONUMENTS_MEN_00001 - Input BD size: 26.13 GB - Approximate total content: [01:58:23.095] Started at 11:32:41 and completed at 15:55:06 (about 4hs 20 min). |
#21519 | Link |
Nothing has changed in that area -- except a newer version of X264. Are you sure the quality setting is the same on both runs? I corrected some code that decided what setting to use when "Automatic" was chosen. The older version would have been more likely to use a faster/lower quality setting in that case -- when it really didn't apply to ALTERNATE encodes (based upon target BD size). It also makes a huge difference if your computer is being used for other tasks at the time of the encode -- as "IDLE" is the default priority for encodes and other processes would likely have a higher priority.
