Domains: forum.doom9.org / forum.doom9.net / forum.doom9.se
Old 2nd January 2021, 21:09   #1001  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Happy new year to you, a5180007 and BloodyRipper , and many thanks for your continued work !
Old 6th January 2021, 10:23   #1002  |  Link
von Suppé
von Suppé's Avatar
It's come to my attention that latest nightly build e6b1ed8 is having problems with importing (blu-ray compliant) m2ts files and mpls files from blu-ray discs. On several occasions I get error: "Track 0 was not recognized and ignored. File name:..." etc.
Several previous versions of tsMuxer don't throw these errors. Tracks concerned are MVC and H264, the latter from both 2D and 3D discs.
Has a bug sneaked in?
Old 8th January 2021, 17:38   #1003  |  Link
KingLir
Originally Posted by imhh11 View Post
On the AppleTV, all you will get out of TrueHD is LPCM right? no bitstreaming.
if you can't find the edited tsMuxer version., you can demux the atmos track to lpcm and remux in a profile 5 MP4. this should work as well.
https://mrmc.tv/forum/viewtopic.php?...3776&start=310
Thanks! The lpcm path worked well on Apple TV 4K.
Regarding different colorspace for profile DV 7 converted to profile 5, can you (or anyone reading this) explain more or pinpoint me to where to read about it ?
I wasn't able to detect the issue, so I am eager to figure what I am missing.
KingLir is offline   Reply With Quote
Old 10th January 2021, 19:25   #1004  |  Link
yannick92
Hi, same problems for me.
thx
yannick92 is offline   Reply With Quote
Old 12th January 2021, 16:19   #1005  |  Link
von Suppé
von Suppé's Avatar
I can confirm that with version 00caad0, the issues with H264 and MVC streams not being recognized, is solved.
Old 15th January 2021, 22:32   #1006  |  Link
cogira
Banned
Dolby True HD Atmos
Hi devs,
can we hope that Dolby True HD Atmos will be recognized in Tsmuxer without the ac3 core?
cogira is offline   Reply With Quote
Old 16th January 2021, 11:49   #1007  |  Link
staina
Why has the every day generate new version tsMuxer, when there are no new fixed?
staina is offline   Reply With Quote
Old 16th January 2021, 12:39   #1008  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Originally Posted by cogira View Post
Hi devs,
This would be most useful, as Dolby TrueHD audio streams with an AC3 core is only required for generating Blu-ray spec disc's...
Old 16th January 2021, 16:17   #1009  |  Link
imhh11
I would love that too but I think they said it wasn't possible to support TrueHD stream without a core but @a5180007 thought a while ago of maybe just adding a blank ac3 core which would be a great solution IMO.
is it still something you will do @a5180007 ?
thank you
Old 16th January 2021, 18:19   #1010  |  Link
filler56789
SuperVirus
filler56789's Avatar
I don't know what "they" said but if I am not not mistaken, ffmpeg already supports pure TrueHD in transport streams, so it would be just a matter of adapting ffmpeg's source-code to the tsMuxer executable.
Old 18th January 2021, 21:09   #1011  |  Link
a5180007
thank you
TrueHD without AC3 is supported by TS but not by HDMV/Blu-ray.
I still plan to work on this after version 2.7 has been released
a5180007 is offline   Reply With Quote
Old 22nd January 2021, 04:49   #1012  |  Link
pacaveli420
There may be an issue with some of the latest versions and muxing to bluray folder. I'm getting discs that aren't playable. I'm still verifying with an older version or two. Anyone else noticing this?
pacaveli420 is offline   Reply With Quote
Old 22nd January 2021, 06:15   #1013  |  Link
pacaveli420
Alright - Official release 2.6.12 muxes a functioning disc
Both of these releases mux a disc that does not play (it just goes to stop without ever starting to play)
w64-nightly-2021-01-17.zip
w64-nightly-2021-01-21.zip
I'm not sure if there's any difference between those 2 as they both say that they're version 0076a07
Something possibly worth noting is that I had to set the SEI/VUI setting to do not change, to get a correctly playing disc.
Regardless of this being on or off (tried discs from both), the mux from the new version is not playable
If there are SEI/VUI issues, you just get playback that glitches every few seconds. I'm not sure if this setting has ever corrected anything, as it's defaulted on, but it certainly breaks things sometimes. Maybe it's better to be defaulted to do not change?
Old 22nd January 2021, 12:54   #1014  |  Link
a5180007
@pacaveli420 my bad... Latest patch introduced a bug in the playlist numbering. I've pushed a fix which should be merged shortly by @BloodyRipper.
Edit: @BloodyRipper could we please go back to the situation where the bintray nightly occurs only when there is a change, and not every night ?
Old 22nd January 2021, 16:48   #1015  |  Link
pacaveli420
Thanks for a quick reply! I'll watch for an updated version
Old 22nd January 2021, 20:02   #1016  |  Link
a5180007
@pacaveli420 fix merged, please try tomorrow's nightly.
Old 31st January 2021, 17:52   #1017  |  Link
zeropc
Originally Posted by filler56789 View Post
According to the official README.md:
This ZIP file for MacOS can just be unzipped and the executables can be used after installing a couple of dependencies.
To install those run the commands below in the Terminal:
ruby -e "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/master/install)" < /dev/null 2> /dev/null
brew install freetype
brew install zlib
which in my not-so-humble opinion is not good enough.
I mean, why no static builds for the Mac operating system?
I have already asked this question but it went ignored
--- by justdan96 and by the "contributors" as well.
Welp, This no longer works for me. I've upgraded to Big Sur and made a clean install. Guess what, I can't use the cmd
Need sudo access on macOS (e.g. the user zeropc to be an Administrator)!
I'm the admin on my computer and normal sudo works. But this cmd is a no go.
We need something solid to fix this once and for all, without the need to use terminal cmds the avarage users has no clue about. The original app didn't have this issue at all. Please make a proper make app. Thanks
zeropc is offline   Reply With Quote
Old 11th February 2021, 21:43   #1018  |  Link
Bgalakazam
Just did the following on Big Sur:
/bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/master/install.sh)"
% brew --version
Homebrew 3.0.1-18-g0211ae4
Homebrew/homebrew-core (git revision d68c42; last commit 2021-02-11)
I ran the first command from my normal user, it prompted for admin password. I was also able to update my freetype and zlib.
Bgalakazam is offline   Reply With Quote
Old 12th February 2021, 18:28   #1019  |  Link
BloodyRipper
BloodyRipper's Avatar
Bintray is scheduled to shut down by the end of May, so we've switched to GitHub for distributing nightly releases. A GitHub account is not needed in order to download these. You can access the release page here.
BloodyRipper is offline   Reply With Quote
Old 15th February 2021, 19:19   #1020  |  Link
a5180007
@xavery thank you, good work !
