Domains: forum.doom9.org / forum.doom9.net / forum.doom9.se
Old 12th May 2021, 09:04   #1061  |  Link
wackopath
Win7-64 4/30/21 nightly build
Tsmuxer doesn't like the following audio format in a M2TS file (mediainfo):
Audio #1
Menu ID                                  : 1 (0x1)
Format                                   : AC-3 MLP FBA 16-ch
Format/Info                              : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Commercial name                          : Dolby TrueHD with Dolby Atmos
Muxing mode                              : Stream extension
Codec ID                                 : 131
Duration                                 : 3 min 58 s
Bit rate                                 : 640 kb/s
Maximum bit rate                         : 5 895 kb/s
Channel(s)                               : 8 channels
Channel layout                           : L R C LFE Ls Rs Lb Rb
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Delay relative to video                  : -778 ms
Stream size                              : 18.2 MiB (1%)
Service kind                             : Complete Main
Number of dynamic objects                : 15
Bed channel count                        : 1 channel
Bed channel configuration                : LFE
Why?
What I wanted to do was remux the M2TS file without the DolbyVideo stream. I can't do that now because tsmuxer is not including the audio stream.
Hi, if you got the audio demuxed (.truehd track) you can use eac3to to add the Dolby Digital core track to it if for some reason it's not present and
then remux...
you can try this command:
eac3to C:\AUDIO\audio.truehd C:\AUDIO\audio.thd+ac3 -no2ndpass
modify the command to your specifications, path and audio file, run this command in the same folder as eac3to.
good luck!
wackopath is offline   Reply With Quote
Old 13th May 2021, 15:25   #1062  |  Link
vanden
PGS subtitle problem in 2D (iso 3D AVC MVC).
Reading the .mpls file we see that there is a problem with the MVC track, it is missing "3d-pg-planes: 32", the subtitles not the "plane #" option ...
Same in the .ssif
A normal 3D blu-ray
Is there a solution ?
vanden is offline   Reply With Quote
Old 14th May 2021, 12:42   #1063  |  Link
yannick92
So many "overlapped frame" ?
Hello,
Quick question: is it normal to have so many overlapped frames during a demuxing?
(full iso)
On the other hand, if I made an mkv with MkvToolnix before and I demux afterwards with Tsmuxer, no "overlapped frame" ...
Is it important ?
Thanks in advance to all
Yannick
And now, after making a MKV, no "overlapped frame":
Last edited by tebasuna51; 15th May 2021 at 10:23. Reason: images not needed, normal in multiple m2ts
yannick92 is offline   Reply With Quote
Old 14th May 2021, 13:37   #1064  |  Link
worov
Hi, everyone.
I'm glad that tsmuxer has updates. It's a great program. Thank for this.
Is there any project of a Linux amd64 build ? That would be great.
Thank you again.
worov is offline   Reply With Quote
Old 15th May 2021, 00:08   #1065  |  Link
a5180007
This is one of those movies where the movie is split among 10 streams. I checked all 10 streams with tsmuxer. What is strange is that one of the streams was accepted by tsmuxer. Mediainfo shows the same info for the one that works and those that don't.
@MrVideo Please give a link to download one of the streams.
@vanden same, please give a link.
a5180007 is offline   Reply With Quote
Old 15th May 2021, 00:14   #1066  |  Link
a5180007
Originally Posted by yannick92 View Post
Hello,
(full iso)
@yannick92 if your blu-ray movie is split in several m2ts, it is normal to have overlapped frames between each m2ts.
Mkvtoolnix does the same as tsMuxer, it muxes the various m2ts into one single m2ts. When you import the mkv into tsMuxer there is only one video stream so no overlapping.
Old 16th May 2021, 08:36   #1067  |  Link
Glarioo
Add blank Playlist for cropped video
Is this option also available for non-cropped video?
Or available in an future update?
Old 16th May 2021, 11:09   #1068  |  Link
vanden
Thanks, splitter in .m2ts but it is sufficient to test : http://vandenk.free.fr/00000.split.1.m2ts
Old 16th May 2021, 13:25   #1069  |  Link
yannick92
Oh okay, thank you again for these explanations, always precise and fast from you.
I will go to bed less stupid tonight, thank you for your kindness ...
Yannick
Old 16th May 2021, 22:17   #1070  |  Link
a5180007
@vanden the link is invalid, your freebox is not reachable.
Old 17th May 2021, 08:33   #1071  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
The link has just worked okay for me...
Old 17th May 2021, 10:01   #1072  |  Link
vanden
you do not arrive on my site !?
Other link OneDrive (+ download / + télécharger)
Old 18th May 2021, 23:15   #1073  |  Link
a5180007
Thanks @vanden, I have the file.
The number of offset sequences is extracted from the metadata info stored in the clpi and the m2ts.
Each offset sequence includes the direction flag and the offset value of the subtitle.
If there is no metadata in the clps or the number of offset sequences in the metadata is zero, then you cannot select any other value than "zero" in tsMuxer as there is no offset data available.
Old 19th May 2021, 13:09   #1074  |  Link
vanden
There is no way to create the metadata ?
Old 21st May 2021, 21:28   #1075  |  Link
a5180007
@vanden definitely not with tsMuxer. Maybe with a professional authoring software.
Old 3rd June 2021, 10:15   #1076  |  Link
SubJunk
It's really great to get this open sourced. We could really use a static build for macOS though, because it currently fails to execute due to missing dependencies.
I'd be happy to test any builds
SubJunk is offline   Reply With Quote
Old 3rd June 2021, 14:39   #1077  |  Link
filler56789
SuperVirus
filler56789's Avatar
DISCLAIMER: I know nothing about the Mac operating system, so I can be wrong...
I *suppose* that a static build of tsmuxer could be easily made if both freetype and and zlib were compiled before tsmuxer itself and then included in it.
However justdan96 invented some lame excuse for not distributing the source codes of zlib and freetype together with tsmuxer's source code.
NOTICE: my "recipe" does work with MSYS2 on Windows, so I suppose it should also work with the default "compiling environment" (so to speak) of any Unixoid operating system.
Old 20th June 2021, 09:25   #1078  |  Link
a5180007
Hello @justdan96, when can we expect release 2.7.0 ?
Old 28th June 2021, 07:40   #1079  |  Link
thepotatoboy
Dear,
a5180007
Hey mate. I'm trying to understand the basics of dolby vision and the mechanisms of how these programs work. I have no background in coding,tech or computer science so forgive me for my lack of knowledge.
I have an Oppo and I was playing around with a movie called nobody. I was using the tsmuxer nightly mac build latest one. I put enable HDMV descriptors( not sure if this is correct to do or not) I made the original blueray folder into the following: these movies were dvhe.07.06
.ts single track dual layer: got dolby vision + atmos
.ts dual track dual layer: got dolby vision + atmos
.m2ts single track dual layer: got dolby vision + atmos
.m2ts dual trakc dual layer: HDR + atmos
I thought, great this is working well. I tried John Wick 3
.ts single track dual layer: freeze with black screen but got atmos logo coming up
.m2ts single track dual layer: freeze with same stuff again
when I pressed INFO on the remote whilst the movie was frozen, I had a look at any issues. At the bottom on HDMI output information, it was saying the movie was outputting SDR? it also was missing some channels on the audio bit I'm pretty sure. I'm happy to take a photo of it if you need. BTW I tried doing the whole movie again with HDMV descriptors disabled, issues still occurred.
( I haven't tried .m2ts dual layer dual track but I'm assuming that'll play in HDR and haven't tried dual track .ts yet)
Can you let me know what's going on, what tsmuxer build to use to solve these issues (happy to use windows too) and in basic terms what HDMV descriptors do?
thanks mate appreciate all your hard work!
thepotatoboy is offline   Reply With Quote
Old 3rd July 2021, 13:34   #1080  |  Link
a5180007
I tried John Wick 3
Hi @thepotatoboy, from DV Blu-rays, tsMuxer outputs only dual track ts/m2ts. What process do you apply to produce single tracks ?
