Old 24th December 2024, 12:15   #25281  |  Link
Francois76l
Hi all
I reported few months ago a problem with v0.79: impossible to play a video without glitches.
Then v0.78 was updated to V0.79.2. It was better but still gave me glitches after approximately 30min of viewing.
The only way to get ride of it was to switch back to windowed mode then full screen again for a minute. That gave me an additional 30min without glitches.
That was not ideal so I went back to v0.78 which is working perfectly.
The PC is powerful (bi-xeon E5 with RTX 3080, MPC-HC/BE/Potplayer with madvr, no queue problem avec 25ms max of rendering time).
This week I upgraded to i9-14900KF + Windows 11 with same graphic card and v0.79.2 is now working 50min without glitches then it starts again. So I switched back to v0.78.
Am I alone?
Happy Christmas to everyone!
HC:Arcam AV888 + BSS-BLU 100-120 + 3x LabGruppen C series + 3x JBL 3678 + 4x Klipsch THX5000 (surrounds) + DIY subwoofer
DISPLAY:JVC RS3100 + Screenline 150"
HTPC: i9-14900KF + RTX3080 + LAV + Madvr
Francois76l is offline   Reply With Quote
Old 25th December 2024, 03:22   #25282  |  Link
clsid
Have you tried disabling Hardware Accelerated GPU Scheduling (HAGS) in the Windows settings? That has helped for other MadVR users with a similar glitch issue after xx minutes.
It is very unlikely that your problem is caused by LAV Filters. Except perhaps if related to audio bitstreaming.
MPC-HC 2.4.0
Old 25th December 2024, 11:46   #25283  |  Link
Francois76l
Thx for advice
I have never tried to disable HAGS so I will give it a try. This feature is not disable by default?
I'm using two separate hdmi output. One for the sound directly to my preamplifier (no 4K compatibility) and another one for the video directly to the projector.
Always in bitstream mode.
The problem appeared with v0.79 with windows 10 and 11.
I never had any issue with older versions.
Old 25th December 2024, 21:48   #25284  |  Link
Try 0.78 to confirm
Old 25th December 2024, 23:53   #25285  |  Link
Francois76l
I'm using v0.78 because of the problem I have with v0.79.X and it's working perfectly
Old 26th December 2024, 00:40   #25286  |  Link
clsid
It is pretty much impossible for LAV to be the cause of this kind of issue. So it might be a case of tunnelvision.
Here are builds in between 78 and 79 to test:
https://files.1f0.de/lavf/nightly/0.78/
Also, when the problem occurs, press Ctrl+J to show MadVR debug OSD and make a screenshot.
MPC-HC 2.4.0
Old 28th December 2024, 20:25   #25287  |  Link
Francois76l
Here is an example (60fps) same problem in 23.976 and HEVC. Many glitches continuously increasing after few minutes. Only way to get ride of it is to exit full screen exclusive for few seconds.
Old 29th December 2024, 01:19   #25288  |  Link
obieobieobie
https://i.ibb.co/DYqHBDs/20241228-181552.jpg
are you running some kind of VRR mode (g-sync or freesync)?
obieobieobie is offline   Reply With Quote
Old 29th December 2024, 14:23   #25289  |  Link
clsid
Start by lowering present in advance queue to 3 as recommended for 2xxx/3xxx series cards.
Lower the other queues back to their default. Reduce NGU very high to high.
Disable HAGS.
MPC-HC 2.4.0
Old 29th December 2024, 20:45   #25290  |  Link
Francois76l
I increased present queue because lower value gave me glitches faster but I will make another try
I can decrease the other queue. NGU algorithm from very high to high doesn't change anything (I already tried).
The graphic card is powerful. I didn't use any sharpness algorithm in madvr (not good, JVC tools are far better now) and my rendering time is low (and v0.78 is working perfectly).
I will report tomorrow or tonight.
Thx for your help !
Old 29th December 2024, 20:46   #25291  |  Link
Francois76l
Only v-sync in driver control panel is activated by default.
Old 30th December 2024, 00:23   #25292  |  Link
Francois76l
Ok it needs time to be 100% sure but I think you are right.
I selected 4 frames in advance in fullscreen exclusive then after 40min of movie I got glitches. Render queue was not able to follow 16 (I had 12 max).
I then selected 14 CPU queue / 10 GPU queue and 4 frames in advance and it looks ok but I must check after watching more movies.
Thanks for your help!
Old 1st January 2025, 23:05   #25293  |  Link
Francois76l
Still not working. It's worse with low queue number (CPU 10 / GPU 8 / 4 frame in advance).
I switched back to v0.78 but thanks for your help
Old 2nd January 2025, 07:09   #25294  |  Link
please try 1-3 not 4.
Old 11th January 2025, 00:04   #25295  |  Link
leeperry
Kid for Today
Hiya fellas, I'm sure I'm missing something but why does MPCHC-BE video decoder allow "D3D12" hw decoding but LAV is stuck to D3D11?
Old 12th January 2025, 19:46   #25296  |  Link
max79
Support request #42
@Nevcairiel
I'm trying to play a stream using LAV Splitter Source filter, I have two URLs, both work in VLC and if I download the M3U8 file, they are completely identical, but for some reason, only first one URL plays in DirectShow, LAV is returning "0x80004005" on "IFileSourceFilter" load function.
Examples:
https://cdn2.ntv.ru/ntv-msk/index.m3u8
https://cdn.ntv.ru/ntv-msk/index.m3u8
Any feedback would be appreciated.
max79 is offline   Reply With Quote
Old 12th January 2025, 20:08   #25297  |  Link
Sunspark
Do you have the right links? Both files say forbidden in them?
Sunspark is offline   Reply With Quote
Old 13th January 2025, 09:18   #25298  |  Link
max79
Hello,
both URLs works. Try to use VPN: Russia
Old 20th January 2025, 22:44   #25299  |  Link
Francois76l
I think I may have found the problem.
In LAV video decoder I selected 32 threads which correspond to what my CPU have. I'm now running with "Auto" and it looks ok. I will confirm in few days!
Old 30th January 2025, 15:58   #25300  |  Link
GTPVHD
https://developer.nvidia.com/nvidia-...c-sdk/download
https://docs.nvidia.com/video-techno...-me/index.html
What's new in Video Codec SDK v13.0?
Encode Features:
H264 interlaced, 10-bit and 4:2:2 encoding support on Blackwell GPUs
HEVC 4:2:2 encoding support on Blackwell GPUs
MV-HEVC: Support MultiView coding in HEVC
AV1 LTR: Support Long-Term Reference frame in AV1
Support AV1 and HEVC Temporal Layer encoding
Support AV1 and HEVC MaxCLL, Mastering Display, and ITU-T T.35 SEI/Metadata
Decode Features:
2x H264 throughput and maximum supported resolution 8192x8192 on Blackwell GPUs.
H264 High10/High422 Profile support (exclude MBAFF) on Blackwell GPUs
HEVC Main 4:2:2 10/12 profile support (exclude YUV400) on Blackwell GPUs
Dynamic decode surfaces allocation
GTPVHD is offline   Reply With Quote
