#861 | Link |
Mr Penguin
Because your Host Certificate was revoked in MKBv72, and at some point you have inserted a disk into your drive which uses MKBv72 or above. Unfortunately, your drive remembers the highest MKB version that it has even been asked to read, regardless of which version MKB your current disk uses.
You need to add a new "| HC |" entry into your KEYDB.cfg file which contains a new non-revoked Host Certificate. Have you seen this? Last edited by MrPenguin; 24th February 2025 at 16:06. |
#862 | Link |
@MrPenguin: Thank you very much for your hint!
Basically the FindVUK-command to find the AACS key of my BD discs works very well now with new new given Host Certificate. Anyway I have some issues with two of my BD discs. I get this error with this BD disc on all my drives (WH16NS60 1.00 LibreDrive enabled, BU40N 1.00 LibreDrive enabled): JOKER_FOLIE_A_DEUX 14:32:34 - Get basic AACS data ------------------------------------------------------------------------------- 14:32:34 - AACS folder on disc is reachable - Validate is possible 14:32:35 - Different VolumeName detected - most likely the disc has been changed... take the new name 14:32:35 - VolumeName >JOKER_FOLIE_A_DEUX< 14:32:35 - DiscId >AA704C4B1A154F305153A47651F282FDB13F9BA2< (2024-10-16) 14:32:35 - DiscType >BD< 14:32:35 - MKB Revision >68< 14:32:35 - Disc-BusEncEnabled >1< 14:32:35 - Drve-BusEncCapable >1< 14:32:35 - ==> Bus Encryption active! 14:32:35 - UnitKeyCount >1< 14:32:35 - >>> UnitKeyENC (1) >E78D506D86980DF35649727ED3C399C2< 14:32:35 - UnitKeys recalculated with VUK: 14:32:35 - UnitKeyCount >1< 14:32:35 - >>> UnitKeyDEC (1) >96D5CBF744EEAC3E04791A0A05FDEAEA< ------------------------------------------------------------------------------- 14:32:35 - BusEncryption enabled => either ReadDataKey or disabling of BusEncryption required ------------------------------------------------------------------------------- 14:32:35 - Try to read ReadDataKey from RDK cache 14:32:35 - RDK not found in cache! Cannot validate disc! 14:32:35 - BusEncryption could not be defeated! Stop now. Any ideas? UHD disc: UHD_JW4 FindVUK does not work! It stops working after PART 1 --- GET AACSKEYS DATA Any ideas? I also wanted to make a 1:1 copy (ISO file with all protetctions included) of one my BD discs. I therefore used Xreveal and makemkv with ImgBurn. I then burned this ISO file to disc and then wanted to find the AACS key using FindVUK again. I got this error: 12:30:26 - AACSkeys could not get data with host certificate >4B7AEF00859AF7F8E88AE97418D862FBE404571A< - #BRAKEYS_AacsKeysError< 12:30:26 - Couldn't get MediaKey, VolumeId and VUK from AACSkeys - close now Any ideas? And interestingly non of these burned BD disc does work in my TV Blu-ray player. Thank you very much? Last edited by johannu; 28th February 2025 at 15:01. |
#863 | Link | ||
Mr Penguin
Disable_Bus_Encryption_Cmd = "C:\Program Files (x86)\MakeMKV\makemkvcon.exe" info dev:$DRIVE$ Quote:
You probably just want to use MakeMKV's "back-up" feature with ImgBurn. I don't see why you would need Xreveal here. Last edited by MrPenguin; 28th February 2025 at 16:39. |
#864 | Link | |
Such image would contain all the regular encryption methods (except bus encryption, if you managed to circumvent it - which, AFAIU, is however anyway not really on the medium, so it would be more or less the best raw copy you can get). |
#865 | Link |
@MrPenguin: Thank you very much, the command for defeating bus encryption works flawless...
But now my LG BU40N has revoked this Host Certificate, when I analysed a BD disc using MKBv72... unbelievable... the result is, that I can't use this drive anymore to find AACS keys. It seems, that - as you already said - this drive remembers the highest MKB version that it has even been asked to read. Where does this information be stored in the drive and can it be deleted? Or is there a new non revoked Host Certificate available? Thank you! |
#866 | Link | |
Mr Penguin
![]() Do you have any other drives, apart from your BU40N? I believe your link contains the latest publicly known AACSv1 host certificate, which AFAIK was revoked by MKBv76. There are (unfortunately!) no publicly known AACSv2 host certificates. However, you might want to consider reading the rest of the messages in that thread for advice about AACSv1. Last edited by MrPenguin; 1st March 2025 at 15:51. |
#867 | Link |
Finding The Revocation List... very interesting...
Yes, I also own a WH16NS60 that is not affected from revoked Host Certificate. As long makemkv works with my BU40N it's not a very huge problem that it has revoked known Host Certificates. Last edited by johannu; 1st March 2025 at 18:00. |
#868 | Link |
Mr Penguin
Before I discovered MakeMKV, my solution to this problem was to buy a brand new drive specifically for those MKB versions that wouldn't revoke my Host Certificates. This did at least allow me to continue playing my existing BDs while I was waiting for the next Host Certificate to appear. However, it's obviously not a viable strategy for UHD disks for which we don't have any Host Certificates in the first place.
#869 | Link | |
#870 | Link | |
I wonder whether there's any FLOSS way to dump the regions outside of the regular image. |
#872 | Link | |
![]() Other than that, no. Supposedly Libredrive was going to be made open source at some point but that hasn't happened.
#874 | Link |
Yea, there's a few things in the protected parts of the disc. It's laid out in the AACS specs.
I wasn't arguing against being able to use an image. I create protected images with bus encryption disabled all the time. I was simply correcting the "you have everything you need with an image" part because UNLESS you have the unit keys, which will have to be derived ultimately from an actual disc by someone, the image is not everything you need. What I mean is this, and this is relevant to FindVUK in a tangential way... If no one has scanned the actual disc with something like FindVUK, DVDFab, MakeMKV, then the unit keys can't be found. This means that if you do the following: 1) Disable/Circumvent bus encryption 2) Create ISO image with your favorite image creation tool 3) Try to use the image mounted in Daemon Tools with FindVUK (or alternatively open said image with DVDFab), it will NOT be decrypted UNTIL someone opens FindVUK or DVDFab with the actual disc first That is the reason I point this out. Because we are in the FindVUK thread where this is quite relevant. Someone thinking they can make an image first without scanning the disc with DVDFab, either directly or through FindVUK, won't be able to decrypt it if the unit keys aren't already known.
#875 | Link |
One of the disc entries in the keydb is incorrect but submitting a correct version doesn't seem to fix it. Is it possible to reset this one so I can upload a correct version?
0xA6F5AC52B2EDC7BA254CAD6D491799EEC1EADC03 = BAD_BOYS_FOR_LIFE (Bad Boys for Life - 4K Ultra HD) |
#879 | Link |
Mr Penguin
This disk's entry in KEYDB already appears to be a validated "meta-entry", which suggests that its Unit Key has been proved to work. Does this mean you were successful in updating it?
