Old 20th December 2023, 12:05   #4801  |  Link
Atlantis
Please note, that since v2.29.0 for x265 an AVX2 build is included. If you want a generic build or one, that is even more challenging for your CPU, visit @Patman86 's Releases and simply replace x265.exe.
What should I get for my CPU for best fast results?
11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz
Atlantis is offline   Reply With Quote
Old 20th December 2023, 12:07   #4802  |  Link
Atlantis
Originally Posted by hevron View Post
Version 2.30 - It's still unstable, I'll test it further.
What does that mean? In what way, what happens? I have not installed it yet and want to wait if it's too serious.
Old 20th December 2023, 14:28   #4803  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
i9-11900K can use AVX512, so you may use
https://github.com/Patman86/x265-Mod...12-msvc1937.7z
plus an extended commandline for that occasion, IIRC --asm avx512
Worked nicely here.
https://forum.doom9.org/showthread.p...14#post1976814
https://forum.doom9.org/showthread.p...05#post1982805
Old 20th December 2023, 20:34   #4804  |  Link
Atlantis
Thank you. I will try it and do 2 tests with AVX2 and AVX512 and report here.
Old 1st January 2024, 11:41   #4805  |  Link
Zetti
Version 2.31.0 is released.
https://github.com/staxrip/staxrip/releases/tag/v2.31.0
Old 1st January 2024, 23:34   #4806  |  Link
Atlantis
So I did several tests. I don't need to download a separate x265. x265 capable of AVX512 is already included in StaxRip.
for a short 4K HDR test
Without AVX512 - 5.21 fps
With--- AVX512 - 5.82 fps
Old 2nd January 2024, 14:06   #4807  |  Link
Emulgator
Emulgator's Avatar
Yes. I just saw that with 2.31 (actually much earlier), AVX512 option became tickable now.
Beautiful, many thanks, Dendraspis & Patman86 !
Old 3rd January 2024, 20:04   #4808  |  Link
chipxtreme
So I use a pre-set for re-encoding x265 with NVEnc which I've used for a long time now. Seems decent(ish) quality and very fast.
Since v2.30 my Target box is missing options to Adjust Size in MB or Video Bitrate so having to stay on 2.29 for now.
Unless there's something i'm missing?
chipxtreme is offline   Reply With Quote
Old 3rd January 2024, 21:13   #4809  |  Link
kalehrl
Can you add InpaintDelogo plugin:
https://forum.doom9.org/showthread.php?t=176860
Thank you.
kalehrl is offline   Reply With Quote
Old 3rd January 2024, 23:47   #4810  |  Link
Emulgator
Emulgator's Avatar
You would just feed a script calling Inpaint DeLogo.
Old 4th January 2024, 09:46   #4811  |  Link
kalehrl
I tried but StaxRip has it's own plugins folder different from the system Avisynth one.
InpaintDelogo line which works when using system Avisynth didn't work in StaxRip.
I would need to put all InpaintDelogo plugins into StaxRip plugins folder but I've only recently started using it so I'm not sure how to do it.
Old 4th January 2024, 17:14   #4812  |  Link
nakTT
Hi good day.
I'm running the latest version of Staxrip (v2.31.0) using SVT-AV1.
It appear the encoding would fail if I use any other preset other than the default (10). Please help.
Thank you in advance.
Below is the "detail error message":
Error Video encoding (v2.31.0)
Video encoding returned exit code: -1073741795 (0xC000001D)
--------------------------- Video encoding ---------------------------
SvtAv1EncApp 1.8.0-1+3-43997134-[Mod-by-Patman]-x64-msvc1938
"C:\Soft Mix\StaxRip 2.31.0\Apps\Support\avs2pipemod\avs2pipemod64.exe" -dll="C:\Soft Mix\StaxRip 2.31.0\Apps\FrameServer\AviSynth\AviSynth.dll" -y4mp "C:\Users\KAI\Desktop\Mix\Video Encoding Samples\300 HD Short_temp\300 HD Short_new.avs" | "C:\Soft Mix\StaxRip 2.31.0\Apps\Encoders\SvtAv1EncApp\SvtAv1EncApp.exe" --input - --width 1280 --height 528 --output "C:\Users\KAI\Desktop\Mix\Video Encoding Samples\300 HD Short_temp\300 HD Short_new_out.ivf" --frames 181 --rc 0 --progress 2 --preset 9
Svt[info]: -------------------------------------------
Svt[info]: SVT [version]:	SVT-AV1 Encoder Lib v1.8.0-1+3-43997134 [Mod by Patman]
Svt[info]: SVT [build]  :	Visual Studio 2022 64 bit
Svt[info]: LIB Build date: Dec 27 2023 17:06:37
avs2pipemod[info]: writing 181 frames of 24000/1001 fps, 1280x528,
                   sar 0:0, YUV-420-planar-8bit progressive video.
Svt[info]: Number of logical cores available: 4
Svt[info]: Number of PPCS 74
Svt[info]: [asm level on system : up to avx2]
Svt[info]: [asm level selected : up to avx2]
Svt[info]: SVT [config]: main profile	tier (auto)	level (auto)
Svt[info]: SVT [config]: width / height / fps numerator / fps denominator 		: 1280 / 528 / 24000 / 1001
Svt[info]: SVT [config]: bit-depth / color format 					: 8 / YUV420
Svt[info]: SVT [config]: preset / tune / pred struct 					: 9 / PSNR / random access
Svt[info]: SVT [config]: gop size / mini-gop size / key-frame type 			: 161 / 32 / key frame
Svt[info]: SVT [config]: BRC mode / rate factor 					: CRF / 35
Encoding          avs2pipemod[info]: finished, wrote 75 frames [41%].
avs2pipemod[info]: total elapsed time is 4.679 sec.
avs2pipemod[error]: only wrote 75 of 181 frames.
StaxRip.ErrorAbortException: Video encoding returned exit code: -1073741795 (0xC000001D)
   at StaxRip.Proc.Start() in D:\Code\Github\staxrip\staxrip\Source\General\Proc.vb:line 353
   at StaxRip.SvtAv1Enc.Encode(String passName, String commandLine, ProcessPriorityClass priority) in D:\Code\Github\staxrip\staxrip\Source\Encoding\SvtAv1Enc.vb:line 74
   at StaxRip.SvtAv1Enc.Encode() in D:\Code\Github\staxrip\staxrip\Source\Encoding\SvtAv1Enc.vb:line 40
   at System.Threading.Tasks.Parallel.<>c__DisplayClass4_0.<Invoke>b__0()
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   at StaxRip.GlobalClass.ProcessJob(String jobPath) in D:\Code\Github\staxrip\staxrip\Source\General\GlobalClass.vb:line 379
I found this among the "detail error message" above. Could this be the problem? Or it was just a symptom of an underlying problem that might be beyond my comprehension as just a normal user?:
nakTT is offline   Reply With Quote
Old 8th January 2024, 09:14   #4813  |  Link
Zetti
Version 2.32.0 is released.
https://github.com/staxrip/staxrip/releases/tag/v2.32.0
Old 8th January 2024, 11:01   #4814  |  Link
DMD
DMD's Avatar
Excellent.
I noticed that the DoVi_Tool app has been integrated, I need to figure out how to use it.
my PC with Ryzen 7950X
DMD is offline   Reply With Quote
Old 11th January 2024, 16:08   #4815  |  Link
Z'Hadum
The new function to export HDR Metadata in 2.32 does not work for me.
I imported my settings from previous Version (last I used before was 2.30)
if I open an HDR file I get the following error:
Error Extract Dolby Vision metadata (v2.32.0)
Extract Dolby Vision metadata returned exit code: 2 (0x2)
It's unclear what this exit code means, in case it's
a Windows system error then it possibly means:
# for hex 0x2 / decimal 2
  STATUS_WAIT_2                                                  ntstatus.h
  ERROR_FILE_NOT_FOUND                                           winerror.h
# The system cannot find the file specified.
# as an HRESULT: Severity: SUCCESS (0), FACILITY_NULL (0x0), Code 0x2
StaxRip.ErrorAbortException: Extract Dolby Vision metadata returned exit code: 2 (0x2)
   at StaxRip.MainForm.ExtractDolbyVisionMetadata(Project proj) in D:\Code\Github\staxrip\staxrip\Source\Forms\MainForm.vb:line 3485
   at StaxRip.MainForm.ExtractHdrMetadata(Project proj) in D:\Code\Github\staxrip\staxrip\Source\Forms\MainForm.vb:line 3418
   at StaxRip.MainForm.OpenVideoSourceFiles(IEnumerable`1 files, Boolean isEncoding) in D:\Code\Github\staxrip\staxrip\Source\Forms\MainForm.vb:line 2242
If I set the Options-> Video -> Extract HDR Metadata to "none"
it seems to work again. Do I miss somthing I have to setup to get HDR MEtadata extraction to work?
Z'Hadum is offline   Reply With Quote
Old 15th January 2024, 19:40   #4816  |  Link
Zetti
Version 2.33.0 is released.
https://github.com/staxrip/staxrip/releases/tag/v2.33.0
Old 15th January 2024, 21:01   #4817  |  Link
shodan5000
The new HDR metadata extraction is super handy. But what if I intend on cropping the video? How can I ensure that the RPU file is also cropped? Is that a function/UI option that needs to created?
shodan5000 is offline   Reply With Quote
Old 16th January 2024, 17:16   #4818  |  Link
Morku
I was wondering the same and so got the answer from the Dev:
Dendraspis
08.01.2024 15:55
The -crop command is always used. I've tested it with cropped and uncropped encodes and MediaInfo as well as the players were always happy with the outcome. Please tell me if it doesn't work for you.
Morku is offline   Reply With Quote
Old 16th January 2024, 21:01   #4819  |  Link
shodan5000
Awesome. Thank you for the follow-up.
Old 16th January 2024, 23:39   #4820  |  Link
Bluedraft
Hello, I have a problem with staxrip and some denoise filters, every time I try to load smdegrain or mdegrain I get the following error
Script Error
Cannot load file 'C:/Apps/StaxRip-v2.30.0-x64/Apps/Plugins/AVS/AviSynthShader/Shader-x64.dll'. Platform returned code 126:
The specified module could not be found.
The file Shader-x64.dll exist and it's exactly in the path mentioned in the error.
I tried with staxrip 2.28 that worked perfectly in the past with these filters but now I get the same error, also tried with the latest version v2.32 but it happens the same also.
Any idea of what could be happening? I'm using staxrip in Windows 10 64bits.
Bluedraft is offline   Reply With Quote
