Domains: forum.doom9.org / forum.doom9.net / forum.doom9.se
Old 4th February 2015, 16:27   #81  |  Link
HolyWu
Originally Posted by zerowalker View Post
SMDegrain acts a bit different compared to the Avisynth version on the same settings.
Is there some Default settings that are different?
Nope. The only big difference should be the prefilter setting which has been changed to use sbr for prefiltering. The others should be quite the same.
Test the core mvtools part first on your own to check whether the issue comes from mvtools itself. Here are equivalent settings for AVS and VS respectively.
super = MSuper(rfilter=4)
bv2 = MAnalyse(super, isb=true, delta=2, overlap=4, search=3, truemotion=false)
bv1 = MAnalyse(super, isb=true, delta=1, overlap=4, search=3, truemotion=false)
fv1 = MAnalyse(super, isb=false, delta=1, overlap=4, search=3, truemotion=false)
fv2 = MAnalyse(super, isb=false, delta=2, overlap=4, search=3, truemotion=false)
output = MDegrain2(super, bv1, fv1, bv2, fv2, thSAD=500, thSADC=250)
super = core.mv.Super(clip, rfilter=4)
bv2 = core.mv.Analyse(super, isb=True, delta=2, overlap=4, search=3, truemotion=False)
bv1 = core.mv.Analyse(super, isb=True, delta=1, overlap=4, search=3, truemotion=False)
fv1 = core.mv.Analyse(super, isb=False, delta=1, overlap=4, search=3, truemotion=False)
fv2 = core.mv.Analyse(super, isb=False, delta=2, overlap=4, search=3, truemotion=False)
output = core.mv.Degrain2(clip, super, bv1, fv1, bv2, fv2, thsad=500, thsadc=250)
HolyWu is offline
Old 4th February 2015, 22:00   #82  |  Link
zerowalker
Tested, it looks a bit different.
It's like the image is pushed up 1 line in some places VapourSynth (in a stretched way).
Does yours look identical?
zerowalker is offline
Old 13th February 2015, 12:55   #83  |  Link
zerowalker
So what am i supposed to do?
They looked different, is it supposed to, i mean it doesn't use the prefilter as far as i can tell, if rfilter isn't that of course? (isn't Prefilter when you add an already filtered imaged and use it as some kind of layer or something).
Old 13th February 2015, 13:20   #84  |  Link
Reel.Deel
A prefiltered clip is usually used in order to try to get better motion analysis; gather motion vectors from the prefiltered clip and then use those vectors on the original clip.
Reel.Deel is offline
Old 13th February 2015, 13:53   #85  |  Link
feisty2
I'm Siri
feisty2's Avatar
prefilter is a special filter used only on vector search clip
when you do the motion compensation (mv.compensate/degrain/...), vectors are required to move blocks from predicted frames to the current reference frame
the point is, you don't have to get vectors from the clip you are performing compensation
like, you can get vectors from a spatial denoised version of the source clip so you can reduce the local SAD value
that's pretty much it
feisty2 is offline
Old 13th February 2015, 17:53   #86  |  Link
zerowalker
So how come my results look different between them if i don't use a prefiltered source to do the vector thing?
I am missing something here, shouldn't they be identical?
Old 13th February 2015, 18:55   #87  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Not 100% identical, no. There are some very small differences in the output of Super, which I haven't bothered to investigate. The small differences in Super propagate to every other filter in MVTools. However, I don't think these particular differences are visible in the output of Degrain, so it must be something else. Please show some screenshots (original image, filtered with Avisynth MVTools, filtered with VapourSynth MVTools). Maybe we should take this to the MVTools thread.
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline
Old 26th February 2015, 14:38   #88  |  Link
Tarutaru
A deadly Taru!
Tarutaru's Avatar
Hi, QTGMC won't start and throw this error
$ vspipe Untitled.vpy -
Segmentation fault (core dumped)
and I got this in dmesg
traps: vspipe[17476] general protection ip:7f1b98e4d6cd sp:7f1b8e384c30 error:0 in libgenericfilters.so[7f1b98e48000+10000]
Is there something wrong with the genericfilters or some other problem? Thanks!
(OS - Linuxmint 17.1 x64)
Script -
import vapoursynth as vs
import havsfunc as haf
core = vs.get_core()
core.std.LoadPlugin('/usr/lib/x86_64-linux-gnu/libffms2.so.3')
ret = core.ffms2.Source(source='foo.bar')
ret = haf.QTGMC(ret, Preset='Medium', TFF=True)
ret.set_output()
Don'taru push me!!
Last edited by Tarutaru; 26th February 2015 at 14:43. Reason: Forgot to post the script
Tarutaru is offline
Old 26th February 2015, 15:04   #89  |  Link
Tarutaru
A deadly Taru!
Tarutaru's Avatar
Solved by using Myrsloik's fork.
Thanks!!
Script -
Don'taru push me!!
Tarutaru is offline
Old 15th March 2015, 17:16   #90  |  Link
HolyWu
Update r14.
  • Add functions SigmoidInverse and SigmoidDirect from Dither package.
  • Remove the bitdepth restriction of ediaa function.
  • For functions that use mvtools, now internally apply DitherLumaRebuild to the clip when it's being fed to 'mv.Super' (for the final 'mv.Analyse' only). s0=1 is always used.
  • QTGMC: Use native filter of FFT3DFilter for noise processing if selected.
HolyWu is offline
Old 20th March 2015, 07:40   #91  |  Link
HolyWu
Update r15.
  • HQDeringmod: When invoking generic.Sobel, mthr was not properly scaled with the bitdepth of input clip.
  • QTGMC: When invoking TemporalSoften, thresholds and scenechange were not properly scaled with the bitdepth of input clip.
HolyWu is offline
Old 21st March 2015, 00:14   #92  |  Link
Pat357
Update r15.
Would you consider adding MCBob to HAvsFunc ?
Info & code about MCBob : http://avisynth.nl/index.php/MCBob .
For me the script is really to complicated to rewrite it myself ; otherwise I would have done it already.
Thanks !
Pat357 is offline
Old 21st March 2015, 04:34   #93  |  Link
HolyWu
Thanks !
I don't know, probably no. Isn't MCBob superseded by TempGaussMC which is considered to be more stable?
HolyWu is offline
Old 29th March 2015, 06:07   #94  |  Link
HolyWu
Update r16.
  • Add functions logoNR and SmoothLevels.
  • maa: Use native filter of SangNomMod. Expose 'aa' and 'aac' parameters.
  • SharpAAMCmod: Use native filter of SangNomMod if selected.
  • ivtc_txt60mc: Fix misusing of DitherLumaRebuild.
  • SMDegrain: Update to v3.0d.
  • Cosmetic changes.
HolyWu is offline
Old 2nd April 2015, 18:59   #95  |  Link
MonoS
I think there's a little bug into QTGMC.
When using InputType 2-3 at line 1013 got passed to mv.Mask a 16bit clip, but the plugin require a 8bit clip
Solved dithering srchClip like so [i mostly use 16bit QTGMC so i'm fine with this change]
inputTypeBlend = core.fmtc.bitdepth(core.mv.Mask(core.fmtc.bitdepth(srchClip, bits=8), bVec1, kind=1, ml=ProgSADMask), bits=16)
There's another instance in the code of mv.Mask, but wasn't triggered by my script
MonoS is offline
Old 3rd April 2015, 03:18   #96  |  Link
HolyWu
It looks like jackoneill forgot to update mv.Mask to support 16 bits as well.
HolyWu is offline
Old 14th May 2015, 14:19   #97  |  Link
jeremy33
Hello,
I try to use LSFMod but I have this error "Erreur de segmentation" (Segfault)
If I try clip = haf.QTGMC(clip, Preset='Medium', TFF=True) I have this error "Exception en point flottant" (Floating point exception)
What's the problem ?
Thank you
jeremy33 is offline
Old 14th May 2015, 15:34   #98  |  Link
djcj
What license is HAvsFunc?
djcj is offline
Old 14th May 2015, 16:32   #99  |  Link
HolyWu
Originally Posted by jeremy33 View Post
Hello,
Thank you
Sorry, I can't reproduce it on both 32 and 64 bits. What version of Python and VapourSynth did you install? Did you use vspipe to test your script? Normally you should get a traceback pointing out the code at which line caused the exception.
No license, just like most of the AVS scripts.
HolyWu is offline
Old 14th May 2015, 17:32   #100  |  Link
jeremy33
I'm on Netrunner 14 x64 (Ubuntu 14.04 derivative) and I use Python 3.4.0 and VapourSynth 27.
I use MPV, I also tried with Vspipe, and I only have this error with LSFMod : Segfault
jeremy33 is offline
