Domains: forum.doom9.org / forum.doom9.net / forum.doom9.se
Old 2nd April 2025, 16:48   #41  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
What are the advantages/disadvantages of enabling or disabling seekpreroll?
Old 2nd April 2025, 19:08   #42  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
It's more or less for debugging purposes only. Don't touch it unless you think there's a very good reason.
Myrsloik is online now   Reply With Quote
Old 2nd April 2025, 19:12   #43  |  Link
wonkey_monkey
Then I will no touchy
Old 19th May 2025, 17:14   #44  |  Link
Myrsloik
Myrsloik's Avatar
R12-RC1 is now available and fixes even more odd corner cases.
It also adds automatic fallback to CPU decoding if no hardware decoder exists for the current format.
Old 21st May 2025, 16:51   #45  |  Link
Selur
Selur's Avatar
Thanks, the new auto fallback to CPU does seem to work fine!
Cu Selur
Hybrid here in the forum, homepage, its own forum
Old 14th October 2025, 00:18   #46  |  Link
isidroco
Hi, tried BestSource2 v10 and latest v13 and both gives silent audio when opening .VOB with AC3 (tried both 5.1: atrack=1 and 192k stereo: atrack=2):
v= BSSource( "VTS_05_8.vob", atrack=1, cachepath="/")
return v
żany ideas?
Thanks, and great work!
isidroco is offline   Reply With Quote
Old 8th November 2025, 21:58   #47  |  Link
isidroco
Found an issue: VID1.AVI (yuvj422p) was joined with VID2.AVI (yuv420p) using VirtualDub: "VID1-2.AVI". Opening it with BestSource will only return first part of the merged video. Fortunately I still had the originals, so made a script opening each in Avisynth and merging them there (after converting VID2 with ConvertToYUV422). Anyway, maybe in a future version BestSource might be able to deal with mixed AVI inner content, because neither VirtualDub or Player complained.
Old 8th November 2025, 22:27   #48  |  Link
Myrsloik
Myrsloik's Avatar
return v
żany ideas?
Provide a sample
Old 22nd November 2025, 07:28   #49  |  Link
lansing
I ran into a problem with bestsource having frame accurate issue with VOB files. I used DGIndexNV as reference. These are the video length that I got from the different methods, all methods were opened with VD2.
DGIndexNV -> dgi -> load with DGSource:
24:09.248
DGIndexNV -> demux m2v -> mux to mkv:
24:09.248
DGIndexNV -> demux m2v -> mux to mkv -> BestSource:
19:20.960
mkvtoolnix -> mux vob -> mkv:
24:11.183
mkvtoolnix -> mux vob -> mkv -> BestSource:
19:20.960
vob -> BestSource:
19:20:960
BestSource seems to give same wrong frames no matter how I mux the vob.
Old 22nd November 2025, 09:13   #50  |  Link
Myrsloik
Myrsloik's Avatar
How do you know it's wrong? Different from DG stuff by a few frames but that does not a bug make in either of the tools.
Old 22nd November 2025, 10:59   #51  |  Link
lansing
I have noticed that all the mkv one has been automatically ivtc'ed, don't know where that process came from. Changing their frame rate to 24000/1001 will change the video length similar to the dg one.
Old 22nd November 2025, 11:04   #52  |  Link
HolyWu
Maybe you want bs.VideoSource(rff=True) because rff defaults to False.
HolyWu is offline   Reply With Quote
Old 22nd November 2025, 11:58   #53  |  Link
Columbo
Yes. The ratio of times is 0.8 which is consistent with the repeat flags not being honored.
Columbo is offline   Reply With Quote
Old 22nd November 2025, 17:33   #54  |  Link
lansing
You are right, with rff=True, BestSource matches DGSource.
24:09.248
frame: 43434 (comb)
24:09.248
frame: 43434 (progressive)
24:09.248
frame: 43434 (comb)
24:11.183
frame: 43492 (progressive)
24:09.248
frame: 43434 (comb)
vob -> BestSource:
24:09:348
frame: 43437 (comb)
