Old 7th October 2014, 16:07   #21481  |  Link
omegaman7
omegaman7's Avatar
Directshow/LAV 0.63 yes.
(The postman) VC-1 streams, TRUE HD audio 640Kbps
(IMMORTALS) AVC streams\ DTS-HD XLL 1509Kbps MA\Core
It was my intention, to find a blu-ray with significantly different streams. I think I found one lol.
I shall attempt to find a different blu with VC-1, and similar audio to Immortals.
Old 7th October 2014, 16:14   #21482  |  Link
Maybe I missed it, but can you name a commonly available disc that completes out-of-sync? I'd like to try it.
Old 7th October 2014, 16:20   #21483  |  Link
omegaman7
omegaman7's Avatar
I'm afraid Immortals, and The Postman, are currently the only ones tested. I'm about to run SE7EN. It has VC-1 streams, and appears to have an identical audio format to IMMORTALS. Very interested to see the result.
What have you ran in testing? Perhaps I have something you do
Old 7th October 2014, 16:39   #21484  |  Link
Glarioo
Originally Posted by omegaman7 View Post
Tried the newest version 0.63 LAV. No luck. Still out of sync.
@ all others testing LAV. How many source BD's have you tried? I've only tried one. I shall try another, that has significantly different audio streams.
Red Dragon (2002) - Source Video: MPEG-4 (AVC), 1920x1080
Muppets Most Wanted (2014) - Source Video: MPEG-4 (AVC), 1920x1080
Both to MKV Container, 1920x1080, 640Kbs DD5.1
Old 7th October 2014, 16:42   #21485  |  Link
Glarioo
@all
Those having issues with Lav and video/audio sync
Do you have TMT6 installed?
Do you have PDVD installed?
PowerDVD 12.
Old 7th October 2014, 16:43   #21486  |  Link
omegaman7
omegaman7's Avatar
Originally Posted by Glarioo View Post
Red Dragon (2002) & Muppets Most Wanted (2014)
Are MKV backups generally your preference? I guess I'll have to try that next.
Glarioo, can we see a log of Muppets most wanted? I'm curious what the streams are comprised of.
Old 7th October 2014, 17:12   #21487  |  Link
Glarioo
All my backups are MKV. Playback with Dune HD Smart H1.
For Muppets Most Wanted is "Track 4357 (nld): Keeping original audio" also out of sync, i've noticed that today
Log at page 1073 #21452
Old 7th October 2014, 17:14   #21488  |  Link
omegaman7
omegaman7's Avatar
I don't know if attachments are ever approved lol.
I almost always keep the HD audio. Really depends though.
Old 7th October 2014, 17:36   #21489  |  Link
Glarioo
jdobbs, for all the LAV hassle...a donation is on the way.
Old 7th October 2014, 17:59   #21490  |  Link
omegaman7
omegaman7's Avatar
Indeed. I have an extra payday this month. Expect a donation from me real soon too.
Old 7th October 2014, 18:35   #21491  |  Link
MajorEvent
Passed Newbie Inquisition
MajorEvent's Avatar
Jdobbs, I ran "The Postman" last night, and the audio is in complete sync :S
The Postman VC-1 TrueHD5.1
I can confirm this re-encoded and was in sync.
Star Trek Into Darkness MPEG4 (AVC) TrueHD7.1
Re-encoding this one now and will let you know soon.
Non-Stop MPEG4 (AVC) DTS-HD XLL
Out of Sync
I don't have either, Red Dragon or Muppets Most Wanted, but I do have my movie catalog setup with the audio format so I can find specific audio formats quickly. No video format though. I got lucky that Star Trek Into Darkness was MPEG4 (AVC). I re-encoded one other movie that had the out of sync audio but I'm having a senior moment and can't recall what it was,The Signal maybe?
Edit: I'm rolling with LAVFilters 0.62.
MajorEvent is offline   Reply With Quote
Old 7th October 2014, 18:48   #21492  |  Link
MajorEvent
MajorEvent's Avatar
I've removed LAV instructions from the first post. They will also be removed from the README.TXT of the next release. Too bad... it was a much more complete solution than FFDSHOW/HAALI.
My experience has been that LAVFilters can be removed by just a regular uninstall so, if you run into the problem, it's pretty easy to recover especially, like most people, they'll install on top of ffdshow and haali.
Maybe just make a mention of the issue until we're sure it can't be resolved. It might be premature to deep six it but it's your call, of course.
Old 7th October 2014, 18:48   #21493  |  Link
omegaman7
omegaman7's Avatar
We're on to something Jdobbs
Old 7th October 2014, 19:18   #21494  |  Link
MajorEvent
MajorEvent's Avatar
Out of Sync
Looking like the problem is the MPEG4 (AVC). Looking for a VC-1 DTS-HD DLL re-encode next.
Old 7th October 2014, 19:27   #21495  |  Link
omegaman7
omegaman7's Avatar
I'm leaning that way myself MajorEvent. Another VC-1 source(SE7EN) has completed, and audio is perfectly within sync. But I find it hard to believe JDobbs only tested VC-1 sources. AVC is an extremely common source.
SE7EN has same/similar audio format as IMMORTALS.
Old 7th October 2014, 20:52   #21496  |  Link
Glarioo
Red Dragon (2002) - Source Video: MPEG-4 (AVC), 1920x1080, Audio: DTS-HD MA Surround 5.1
Muppets Most Wanted (2014) - Source Video: MPEG-4 (AVC), 1920x1080, Audio 1: DTS-HD HRA Surround 7.1 English, Audio 2: DD 5.1 640 kbps Dutch.
Both out of sync (MKV Container, 1920x1080, 640Kbs DD5.1)
Old 7th October 2014, 20:56   #21497  |  Link
MajorEvent
MajorEvent's Avatar
I think your result clenches it. MPEG4 (AVC) is the culprit. But I'm confused by the result that the time index and frames aren't different from the source. If the video component is the same length, what could be causing the audio to come in so late?
Another VC-1 source(SE7EN) has completed, and audio is perfectly within sync...SE7EN has same/similar audio format as IMMORTALS.
Is there some reason you just don't say what the audio format is?
Most Likely there's something between his setup and ours that makes a difference. For example, do you have PowerDVD installed?
Old 7th October 2014, 21:01   #21498  |  Link
Glarioo
I've got Power DVD 12 installed.
Old 7th October 2014, 21:05   #21499  |  Link
MajorEvent
MajorEvent's Avatar
Even the DD5.1 (is out of sync)? Seems like it affects all audio formats when combined with MPEG4 (AVC) re-encodes.
I saw you mentioned that and was why I asked about it specifically.
Old 7th October 2014, 21:11   #21500  |  Link
mparade
@jdobbs
Is it possible a bug?:
After selecting "Alternate Movie-Only Output" mode and deselecting "Output BD or AVCHD Compliant Structure" and choosing any of the mkv containers and getting the encode to complete the lastcmd still includes several command line options (limitations) relating to a BD compliant structure (e.g. --bluray-compat --ref 4).
