Old 6th May 2023, 11:28   #31461  |  Link
gonca
DGDecode will only work if you have a NVidia card, else use LSMASH
.dgi is the indexed file from DGDecode
DotKill >> make sure you are using the correct bitness (32 or 64) [yes I know that bitness is not a real word]
Same with DGSharpen and DGDenoise (which are part of DGDecode)
FRAME SERVER is basically the plug in that supplies each video frame to the encoder for encoding.
Try within BDRB first
Old 6th May 2023, 17:36   #31462  |  Link
gonca
It was weird too, sometimes I would try to load a plugin that is indeed in my plugins folder, but when I'd try to run it, I would get an error in the preview saying 'no such plugin' I think I tried it with TComb and Decomb521, but even though I do have the dll's in the plugins folder, they wouldn't run. It happened with a few others I tried too. Some would run and some wouldn't. I wonder why...
That is why I explicitly load all plug-ins
That means I can also save them where I want
Old 6th May 2023, 19:10   #31463  |  Link
Sharc
The poor DVD source is still much better than the totally flawed HD crap, IMHO.
Just IVTC it. See here:
https://forum.videohelp.com/threads/...ts#post2689126
Old 6th May 2023, 22:39   #31464  |  Link
Lathe
Lathe's Avatar
Heh... Yeah, I was just going to post Sharc's reply on VideoHelp here. I could not believe that the ultra CRAPPY DVD could be made to look that much better! I'll post his reply below, but the li'l bugger got rid of just about all the combing by doing this. I can always play around with the colours/sharpening, etc. later.
Here was his reply:
@Lathe
The DVD variant is telecined, with pattern glitches and/or dropped frames e.g. where the speaker leaves the desk. You may still IVTC the DVD version and continue from there (and trash the flawed HD variant IMHO):
ffms2("GCDVD.mkv") #or the source filter of your choice
assumeTFF()
TFM().TDecimate() #returns 23.976 progressive video
#... add some denoising etc. of your choice here ....
Old 6th May 2023, 22:41   #31465  |  Link
Lathe
Lathe's Avatar
Yeah, I WAS loading the dll's first, but they still wouldn't run. It could be I think you said that they may be 64 'bitness' instead of 32 which is the version I'm running as per BDRB's requirement.
But, WOW, I couldn't believe that DVD looks SO damn much better now!
Old 6th May 2023, 23:23   #31466  |  Link
Lathe
Lathe's Avatar
Ah, yeah, I think I began to understand that certain dll's only work if you have others they depend on. Maybe that is why some of these don't load. And no, I don't have an Nvidia card. Since I can do the simpler code with the original DVD, I might try dropping it in BDRB and see what happens
Here is the code I am now using with the original DVD:
DirectShowSource("GC.mkv")
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\UnFilter.dll")
assumeTFF()
TFM().TDecimate()
UnFilter(50, 50)
I'm still a little scared to get away from DirectShow, and I believe IIRC that BDRB can only use Avisynth with that. So far, it's not looking too bad! I want to play around with the colours too and get a bit more saturation and perhaps more contrast. I have done that before, it's just been a while and I need to go back and see the settings I used. I'll post a couple of pictures here where I did that with some films. I know some will feel it is overdone, but I liked the way they came out. Just gives it more 'pop', primarily for lower quality films or what I feel where movies were poorly mastered. Don't make fun now, this is just to my 'taste'
***EDIT
BTW, I tried just adding a simple DeNoise() after loading the dll, but again, the preview says that it is missing a library...??? I mean, isn't that just a very basic AVS function? I'm really getting somewhat frustrated as to what dll's will run and which ones won't, GEEZ...
Old 7th May 2023, 00:16   #31467  |  Link
gonca
Try using avsmeter to check your script,
and let us know about the DVD next time
Old 7th May 2023, 00:26   #31468  |  Link
Sharc
I could not believe that the ultra CRAPPY DVD could be made to look that much better! .... I can always play around with the colours/sharpening, etc. later.
I would even consider to convert that movie to greyscale rather than fiddling with colors.
Old 7th May 2023, 15:50   #31469  |  Link
MrVideo
MrVideo's Avatar
I have a separate script in which I convert the MPEG-2 1080i satellite feeds to H.264 1080p23.976 files.The sat feeds no longer exist, but the captured files that I have do. The following is the AVS script:
LoadPlugin("C:\Program Files (x86)\DGAVCDecNV\DGDecodeNV.dll")
dgsource("E:\\source.dgi")
assumetff()
telecide(guide=1)
decimate()
I want to try and see if I can use BDRB to re-encode the MPEG-2 file to HEVC while also doing IVTC on the video. My current method of doing my own encoding to H.264 takes many hours since it uses the software x264 encoder.
Unfortunately, the dgindexnv program is needed in order to create the .dgi file. I can get around that by running it before running BDRB, as the .dgi file then be there for BDRB.
The LoadPlugin line is also not necessary as I will have told BDRB to use DGDecodeNV and the path to it is part of the INI file.
I normally extract the video and audio into separate .m2v and .ac3 files.Not sure if the dgindexnv program will work with the mkv file. The manual doesn't list supported source files. I suppose I can create the separate files but tell BDRB about the MKV file, even though the AVS script will use the separate video file and pass that to the encoder.
Now I just need to tell BDRB to use the HEVC encoder and force encode it.
Oh, there is the following BDRB option:
FIXED_BITRATE=n
where n > 50. 50 what?
All of this may be moot (except the FIXED_BITRATE) if setting the IVTC of 1080i video to on works, as well as getting forced HEVC encoding to work. I'll have to do some testing in a while.
Old 7th May 2023, 17:49   #31470  |  Link
gonca
I believe it should
Old 7th May 2023, 22:31   #31471  |  Link
MrVideo
MrVideo's Avatar
I believe it should
Thanks. Still need to know what FIXED_BITRATE's units are: > 50 Kbps?
Old 8th May 2023, 00:16   #31472  |  Link
gonca
FIXED_BITRATE is in Kb/s
Old 8th May 2023, 00:58   #31473  |  Link
MrVideo
MrVideo's Avatar
Thanks. That info should be in the hidden options file.
Old 8th May 2023, 02:42   #31474  |  Link
MrVideo
MrVideo's Avatar
Here are some options that are in the INI file, but not in the HIDDEN options file, so there is no definition. So if anyone knows what these mean, please post. Thanks.
ENCODER=1
MODE=0
I tried with a short segment of the 1080i MPEG-2 file and it was a bust. No IVTC and it was AVC, not HEVC;
The BDRB INI file contents:
[Options]
VERSION=0.61.0.28
ENCODER=1
MODE=0
TARGET_SIZE=23500
CUSTOM_TARGET_SIZE=23500
AUTO_BURN=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=eng;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=0
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AUDIO_DRC=0
DECODER=3
AVCHD=1
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=1
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
MENU_AUDIO=C:\BD_Rebuilder-0.61.28\tools\blankclip\blank.ac3
IMPORT_THRESHOLD=0
QUICK_PLAY_THRESHOLD=0
MIN_PLAYLIST_MINS=0
MENU_AUTO_BACKGROUND=0
MENU_AUTO_DVDAUDIO=1
MENU_FORCE_QUICK=1
MENU_PLAY_SEQUENTIAL=0
MENU_START_WITH_MENU=1
IMPORT_LIMIT_LANG=0
IMPORT_KEEP_PLAYALL=0
IMPORT_VFR_SCAN=0
FORCE_NOENCODE=0
MENU_FONT=Century Gothic
MENU_FONT_BOLD=1
MENU_FONT_ITALIC=0
MENU_VERTICAL=450
MENU_HORIZONTAL=560
MENU_ACTIVE_COLOR=0xd9ba00
MENU_CUSTOM_COLOR=
MENU_INACTIVE_COLOR=0xd98200
MENU_BACKDROP_OPACITY=0
MENU_ROLLOVER=1
MENU_ITEMS_PAGE=11
ENCODE_QUALITY=2
ONEPASS_ENCODING=0
AUTO_QUALITY=0
IMPORT_VFR_FILM=0
AVSFilter01=selectevery(2,0)
IMPORT_PREPARE_MKV=0
MOVIEONLY_TYPE=28
ALTCRF=23
ALT_TARGET=1024
ALT_CRF_TARGET=1024
ALTMETHOD=0
ALTAUTOCROP=0
NVENC_CAPABLE=1
UHD_CONVERT_ENABLE=1
UHD_V3_MODE=1
FIXED_BITRATE=7000
FORCE_ENCODE=1
[Paths]
WORKING_PATH=E:\BD-REBUILDER\WORK\
SOURCE_PATH=E:\BD-REBUILDER\WORK\IMPORTS\BDRB-TEST-FILE\
DGIndexNV=C:\Program Files (x86)\DGAVCDecNV\DGIndexNV.exe
DGDecNV=C:\Program Files (x86)
Old 8th May 2023, 02:58   #31475  |  Link
MrVideo
MrVideo's Avatar
I discovered that IVTC_PULLDOWN was incorrect. I set it to 0 and added IVTC_1080i=1 to the INI.
Well that was worse. At least this time the log said that it was doing IVTC, but immediately failed when starting the reencode.
Old 8th May 2023, 03:28   #31476  |  Link
Lathe
Lathe's Avatar
Will do, thanks Bro!
Old 8th May 2023, 03:29   #31477  |  Link
Lathe
Lathe's Avatar
Interesting idea, hadn't thought of that...
Old 8th May 2023, 03:37   #31478  |  Link
Lathe
Lathe's Avatar
Oh, just one more thing... How can I get a Denoise filter to work. It won't load and run any kind of Denoise dll's for some odd reason (again, the mystery of why some dll's when loaded run and some don't..) Can anyone suggest a Denoise filter that WILL run in the version of AVS that is present for BDRB? (2.58?) Just for the hell of it, here is a picture of my plugins folder. Maybe someone can tell me why some of them run and some of them are simply not recognized with the error: '***** does not exist'
Old 8th May 2023, 03:41   #31479  |  Link
MrVideo
MrVideo's Avatar
Once last try, using my own AVS script. It too failed to reencode. The BDRB AVS script:
#Created by BD Rebuilder - v0.61.28
LoadPlugin("C:\Program Files (x86)")
DGSource("E:\BD-REBUILDER\WORK\WORKFILES\VID_00001.DGI", fieldop=0)
dgsource("E:\\BDRB-test-file.dgi")
assumetff()
telecide(guide=1)
decimate()
ConvertToYV12().AssumeFPS(30000,1001)
A few things wrong. The first LoadPlugin is useless. I think the path in the INI file (shown above) is wrong. No idea how in the past it got split into two lines. Once I fixed that, the reencode no longer fails. I also removed my LoadPlugin and dgsource lines. But, look at the last line: AssumeFPS(30000,1001). That is not good. At that point in time it is now 23.976.
When it finished encoding, the video was indeed no longer 2:3 pulldown. But after the encoding BDRB claimed it failed. It might be related to the fact the video is really 23.976, not 29.97. I pulled the video and audio into VideoReDo and observed that the 2:3 was gone and that it plays a little fast.
So, I need to find out how to get rid of the AssumeFPS(30000,1001) and get it do an HEVC encoding instead of AVC.
Old 8th May 2023, 03:53   #31480  |  Link
MrVideo
MrVideo's Avatar
The AVISynth DLL is installed for the whole computer, not just BDRB: C:\Windows\System32. Make sure that the plugins are 32 bit for the 32 bit installed AVISynth. Even though my Win7 is 64 bit, I've installed the 32 bit version. AIUI, the 64 bit version doesn't really gain anything.
Please list a plugin that doesn't load.
