Thread Tools Display Modes
Old 21st June 2024, 19:46   #561  |  Link
hypnotize666
Qaac Aac lc sbr He 192 Normalize
I found it a bit fishy but I still tried with this command: stdout.wav -normalize | qaac -v 192 --he --ignorelength -o %_.m4a - but the strange thing is that by clicking on the menu at the end it does not mark a .m4a type file but rather an .aac type file as I wasn't sure I tried 2 ways but without success 2: stdout.wav -normalize | qaac -v 192 --ignorelength -o %_2fre.aac -
hypnotize666 is offline   Reply With Quote
Old 22nd June 2024, 09:35   #562  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by hypnotize666 View Post
... but why in the log does it indicate a nero direct show codec error?
Because eac3to need Nero 7 installed to decode AAC, NeroAacDec is not enough. Decode it before to wav with ffmpeg (A/V Recode) and after normalize and recode to AAC.
Old 22nd June 2024, 09:41   #563  |  Link
tebasuna51
tebasuna51's Avatar
What menu?
Without success?
Both commands works fine for me (of course over a source than can be decoded by eac3to), the first create a file_.m4a (aac HE in mp4 container) and the second a file_2fre.aac LC
Old 23rd June 2024, 19:06   #564  |  Link
mannequin80
Well, I prefer some clip than don't listen the dialogs, with the 0.707 coeficient the volume of center channel is preserved, with low coeficients means attenuate the dialogs.
is there a universal way to enhance the dialogue (center channel) without applying additional filters (like dynaudnorm)?
mannequin80 is offline   Reply With Quote
Old 24th June 2024, 09:54   #565  |  Link
tebasuna51
tebasuna51's Avatar
@mannequin80
Read the thread convert 5.1 to stereo
Players can be instructed to enhance the FC in the downmix, for instance with mpc-hc:
Old 24th June 2024, 22:02   #566  |  Link
mannequin80
@mannequin80
i'd love to keep it at 5.1 and make it playable across various devices with good sounding dialogue while maintaining the dynamic range as much possible and not using any hardware methods like DRC or Night Mode. after looking at multiple methods, i can't find a better solution than "volume=x.xdB (if needed), dynaudnorm=p=0.9:m=2:g=31:f=300". there's no easily detectable volume pumping even in complicated scenes BUT the drawback of this method is the loud parts (like music, etc) become even louder so it's difficult to preserve the balance. wondering about any additional tweaks to try.
Old 26th June 2024, 23:39   #567  |  Link
DanDare1983
Do you have to -keepdialnorm when extracting atmos? I remember using the old eac3to and it would automatically remove dialnorm as it was supposed to help in some way. I'm using -keepdialnorm from now on as I think it's the best thing to do especially as dgdemux and makemkv keeps dialnorm too.
DanDare1983 is offline   Reply With Quote
Old 27th June 2024, 08:57   #568  |  Link
tebasuna51
tebasuna51's Avatar
Just a few days before:
The data are preserved (same size and MediaInfo show both like JOC) but with Dialnorm changed (if show -31 dB maybe it is changed) seems not compliant.
Extracted with -keepDialnorm my Denon player show DD Atmos and decoded with Dolby Reference Player seems fine.
Without -keepDialnorm (or converted to mkv from m2ts with MkvToolnix) my Denon player show DD+ and decoded with Dolby Reference Player we obtain only silence.
Like I say MediaInfo show JOC for both and Cavernize decode both with the same output (seems more permissive).
Old 2nd August 2024, 13:44   #569  |  Link
spinkeln
Deleted
Last edited by spinkeln; 9th August 2024 at 11:22. Reason: Will be moved to it's on thread
spinkeln is offline   Reply With Quote
Old 5th September 2024, 07:31   #570  |  Link
MrVideo
MrVideo's Avatar
Using eac3to v3.52, I've discovered that using -keepdialnorm wasn't necessary as eac3to indicates, when it starts to operate on the source, that it is "Keeping dialnorm."
The job that was doing was extracting the thd and ac3 streams from a mkv file so that I can THD merge the two.
Old 5th September 2024, 08:08   #571  |  Link
MrVideo
MrVideo's Avatar
Is it possible with (Us)Eac3to to create an eac3 file with an empty core, like what can be done with a THD stream within a MKV file?
Old 5th September 2024, 09:14   #572  |  Link
tebasuna51
tebasuna51's Avatar
It is not necesary if you have the -keepdialnorm in the eac3to.ini file.
UsEac3to can create eac3 files using ffmpeg (only to 5.1 and without ac3 core, only eac3 frames) but I can't understand the relation with THD.
To create a THD track BD compliant need a ac3 file, not eac3.
To create a eac3 track BD compliant you can't use ffmpeg (maybe Dolby Encoder Engine).
Old 6th September 2024, 03:53   #573  |  Link
MrVideo
MrVideo's Avatar
It is there, but I never put it there. Must be part if the distro.
THD was only mentioned as an example.
Old 6th September 2024, 08:20   #574  |  Link
tebasuna51
tebasuna51's Avatar
Yes, it is. I don't like that option and I delete that option from the .ini file.
Old 6th September 2024, 22:23   #575  |  Link
MrVideo
MrVideo's Avatar
Why don't you like the option?
Old 7th September 2024, 10:27   #576  |  Link
tebasuna51
tebasuna51's Avatar
The Dialog Normalization different than -31 dB force to compliant decoders to attenuate the E-AC3 tracks all the sound.
Thats is a problem to recode, or listen, compared with others codecs.
For instance, with old DVD's with AC3 and DTS tracks all the people prefer the DTS track because sound high, normally 4 dB high with standard DN at -27 dB, than the same AC3 track.
The DTS encoder is not better, at same bitrate, than the AC3 only it is decoded without attenuation.
The same source encoded with GUIDE: How To Properly Encode Dolby Digital Audio (AC3) recomendations sound with less volume than encoded with AAC, DTS,...
The same for the Dolby recomendation about Dynamic Range Compression, when we need recode a E-AC3 track we need force decoders (ffmpeg, avs decoders) to use drc=0.
When ffmpeg encode AC3 or EAC3 by default always use DN -31 dB and DRC=none to offer the same behaviour than others codecs.
If all the audio was encoded with Dolby defaults DN/DRC all can be ok, but if you listen Dolby compliants tracks and TV comercials or CD audio (Loudness war) or the same track encoded with other codec, you need modify the volume button every time.
Old 8th September 2024, 08:13   #577  |  Link
MrVideo
MrVideo's Avatar
Thanks for the info. I certainly do not want DRC. I'll remove the keepdialnorm option from the ini.
Old 8th September 2024, 10:06   #578  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
With regard to Dolby audio streams, is Dialnorm applied to all the available channels or just the centre channel?
Old 8th September 2024, 22:11   #579  |  Link
tebasuna51
tebasuna51's Avatar
To all. Just a part of GUIDE: How To Properly Encode Dolby Digital Audio (AC3):
The decoder will perform an attenuation of (31 + dialnorm) dB to the program material when played back. So, in this case, the decoder will attenuate by (31 + -18) = 13 dB. This will bring the average sound level of the material to (-17.6 - 13) = -30.6 dBFS. The program is now played back at approximately -31 dBFS, the reference level.
-31 dBFS is a lower average volume level than what is typical from other sources. It will be noticeable that you will have to turn the volume up on your system when playing a DVD versus playing broadcast, tape, or other non-Dolby Digital program material.
Old 9th September 2024, 09:27   #580  |  Link
SeeMoreDigital
Thread Tools
