#582 | Link |
![]() Join Date: Feb 2005
No problem here:
eac3to v3.52 command line: "C:\Portable\eac3to\eac3to.exe" "D:\Temp\t\00_HD.mkv" -progressnumbers -log="C:\Portable\eac3to\UsEac3to\UsEac3To.log" ------------------------------------------------------------------------------ Running in fast mode Removing dialnorm MKV, 1 video track, 1 audio track, 0:00:21, 25p 1: h264/AVC, English, 720p25 2: DTS Hi-Res, 7.1 channels, 2814kbps, 48kHz, dialnorm: 0dB (core: DTS-ES, 5.1 channels, 1509kbps, 48kHz, dialnorm: 0dB) |
#583 | Link |
Acid fr0g
I did a clean installation of last version and no way to make it work, both drag and dropping and opening. Tried to rename file to a single character but nothing helped.
It opens a cmd window telling "analyze" and then the useac3to shows eac3to help page. Would you please post here your eac3to.ini file? Is there any way to trace the commands sent to eac3to? The log doesn't contain them.
@turment on Telegram |
#584 | Link | |
UsEac3to not need any installation other than fill the Settings options (if can't obtain them automatically):
Path to eac3to Path to MkvMerge Path to TsMuxer Encoders Folder Output Folder You don't need eac3to.ini at all because the -progressnumbers -log= is added by UsEac3to (or can be added manually), but I have: Quote:
#587 | Link | |||
Work fine here:
To recode to thd 7.1 you need any commercial encoder. |
#589 | Link |
I've come across a DTS-HD MA 5.1 track which has a 1000ms DELAY. The Log is telling me that a remaining delay of -2ms could not be fixed. I understand that -2ms is nothing to worry about but could someone explain how eac3to has got the delay down to -2ms? I've also seen an ATMOS track with a delay of 3003ms too. Also if i was to just convert the track to ac3 would it sort the problem? I'll also add that the video is 2: h264/AVC, 1080i50 (16:9).
#595 | Link |
Life's clearer in 4K UHD
Out of interest... Is there any reason why you don't want to use the 5.1 DTS 'core'?
#597 | Link |
DanDare1983 is encoding from lossless 7.1 DTS-HD MA to lossy 5.1 Dolby Digital. So my question is, why not extract 'and play' the lossy 5.1 DTS stream instead of encoding and playing a lossy 5.1 Dolby Digital stream?
#598 | Link |
Of course, but some players (like some TV's, for instance the mine) can't support even the lossy core DTS, without problem with AC3 (my TV can send by SPDIF the AC3, also EAC3 5.1.2 to my Denon 5.1.2)
There are also the size to store, the AC3 640 Kb/s have equivalent quality than DTS core 1510 Kb/s (size x 2.3) |
#599 | Link |
Hi just a quick question. I have a playlist where the DTS-HD MA track has a delay of -1001ms. eac3to gets it down to -2ms which i understand is perfectly fine. Can I ask if the DTS core also has the same delay? If so, does that also get fixed?
#600 | Link |
In fact when eac3to do the delay correction only add silence frames at the begining (delay +) , and that silence frames are only core frames because don't need MA extensions to codify silence.
To delay - delete first full frames (core+MA extensions) Then the core is fixed also. Last edited by tebasuna51; 14th January 2025 at 10:19. |
