Old 25th July 2024, 16:30   #801  |  Link
Roof Tile
Hello Nalor! I was finally getting back into getting some blu rays through the VUK process when one of them decided to be a bit strange. I was using VUK on the blu rays for the TNG series boxset and all of them went through it just fine, all except Season 2 Disc 1. For some reason VUK seems to be having trouble figuring out what to do with that one. The disc seems perfectly fine and even plays in VLC like normal (which doesn't surprise me given the series popularity made them all being scanned already likely). It's just strange that it's having trouble with it compared to the others. In any case, I've taken the log file and uploaded it to this post for your perusal to find what may be causing the problem. As always I thank you extremely for your work and hope you stay happy and healthy!
Attachments Pending Approval
File Type: txt TNG S2 - Disc 1 Log File.txt
Roof Tile is offline   Reply With Quote
Old 28th July 2024, 19:38   #802  |  Link
twuplay
Hello! I just noticed in the keydb.cfg some newer releases include both unitkeys and VUKs. If VUKs are no longer available from the DVDFab memory dump, how are people obtaining them? Also, when it comes to decrypting, what is the difference between using a VUK and unitkeys? Thanks!
twuplay is offline   Reply With Quote
Old 29th July 2024, 23:41   #803  |  Link
nalor
Please upload the log somewhere else as it's still not approved here. Thanks!
Old 29th July 2024, 23:49   #804  |  Link
nalor
It does not make a difference if using VUK or directly UnitKeys. Internally the VUK is used to calculate the UnitKeys - so in the end it's always UnitKeys which are used to decrypt something.
And about the source of this VUKs: I guess the users have host certificates not published yet.
Old 30th July 2024, 02:00   #805  |  Link
coricopat
Is it actually the case that VUKs are no longer available via DVDFab?
As long as these people who do have unpublished (especially also AACS2.0) HCs share their VUKs / UKs (or kinda "share" them like with DVDFab), I think it's actually for the benefit of the community (of people which want to be able to play back the stuff they bought on open source platforms or even once after BluRay players are no longer produced), that these HCs are not made public - makes it more difficult to revoke them ;-)
coricopat is offline   Reply With Quote
Old 31st July 2024, 18:32   #806  |  Link
coricopat
Originally Posted by nalor View Post
Today I've received my first Blu-ray where Passkey 9.4.5.2 told me I have to update first ...
Does someone have a SHA256 or similar hash for the installer of 9.2.1.2 (IIRC that was the last version that worked)? DVDFab doesn't offer older versions to download, it seems.
Old 31st July 2024, 19:05   #807  |  Link
DrinkLyeAndDie
DrinkLyeAndDie's Avatar
Passkey 9.2.1.2 (2017.07.24)
SHA-256: 15C9B88592B8751C8D9B19A508D318A02824E5745FF2B1978C8F70FFE6A7990E
DrinkLyeAndDie is offline   Reply With Quote
Old 31st July 2024, 19:10   #808  |  Link
coricopat
thx :-) ... and again, matches the download from videohelp.com. (So should be safe, unless of course you're the admin there ;-P)
Old 31st July 2024, 19:58   #809  |  Link
mick0
Yes, DVDfab doesn't use VUKs anymore and it has never used them for UHD discs.
However, if you want VUKs for non-UHD discs, why not try "FindVUK - AACSkeys.bat" instead of old DVDfab version?
You may have to copy-paste Device Keys and Host Certificate from this post into your KEYDB manually though.
mick0 is offline   Reply With Quote
Old 31st July 2024, 20:31   #810  |  Link
coricopat
Well in principle the VID is enough, so I don't mind.
But just for "completeness"... is there "open" any way to get the VUKs vor UHDs?
IIRC, one could not extract them from MakeMKV's disatt.dat either.
Sure, that's anyway clear :-)
Old 31st July 2024, 20:59   #811  |  Link
DrinkLyeAndDie
YW. Yeah. Definitely not.
Old 31st July 2024, 23:38   #812  |  Link
nalor
Passkey 9.4.5.2 is the last version that worked, everything later does not include unitkeys any longer in a way where I know how to parse them.
Old 1st August 2024, 03:40   #813  |  Link
Roof Tile
Ah, didn't see that the file wasn't approved yet, strange. Well, here's a MEGA link to the tiny thing for your perusal.
Old 1st August 2024, 16:50   #814  |  Link
nalor
Thanks! Checked the log and something is failing during analysis of the memory dump.
Can you please also upload the memory dump?
(the file >F:\Vxxxxxff\Blxxxxxuff\FindVUK Tool\FindVUK Program\dump\85670F37043778F22A8243E816DACC20946941DB_STAR_TREK_TNG_S2_D1.dmp<)
Thanks!
Old 2nd August 2024, 13:01   #815  |  Link
Roof Tile
No problem, here is a MEGA for that. Hope it has something useful for you!
Old 2nd August 2024, 23:47   #816  |  Link
nalor
Thanks! This helped! It's really funny that this problem never appeared before ...
Please try this version here: FindVUK 1.77
In case it's working I'll publish it as new official version
Old 3rd August 2024, 12:23   #817  |  Link
Roof Tile
Yup, seemed to work normally and uploaded all the stuff as usual! Thanks for the fix!
Old 3rd August 2024, 23:30   #818  |  Link
nalor
Published FindVUK 1.77 "officially".
No new features, just 2 bugfixes.
Old 22nd August 2024, 15:18   #819  |  Link
coricopat
Is someone else seeing issues with FindVUK + DVDFab since version 13.0.2.5?
Old 22nd August 2024, 16:12   #820  |  Link
coricopat
It works again after downgrading to 13.0.0.4 (which is the last version from which I have a standalone installer - I guess the versions in between were not available as standalone installer, or does any one have them?)
Send the logs with the error message via PM @nalor.
