#30982 | Link | |
![]() Join Date: Oct 2001
Note that if you run TSMUXER with an E-AC3 source it creates the structure, muxes the M2TS, and creates a CLPI (with some wrong information in it). Only the MPLS is missing. BD-RB has the ability to create its own CLPIs and MPLSs. Last edited by jdobbs; 10th December 2021 at 15:01. |
#30985 | Link | |
Please don't.
#30987 | Link |
It looks like my attempt to manually get this working is a failure. I've managed to freeze my Sony UHD player when I select the first video (of two) to play.
What I did was to mux the M2TS file from the BDRB backup output with the original DD+ audio. tsMuxeer actually didn't like the DD mono audio that BDRB created. I edited (with BDEdit 0.49) the BDRB created playlist and changed the DD/mono to DD+/multichannel and changed the chapter marks. I also had to rename the clipinfo/playlist/M2TS files that tsMuxer created to 00001 and 00002 before copying them into the BDRB created structure. I should try burning the tsMuxer created folder to see if it does, or does not, freeze the player. This is sure becoming a lot of work. |
#30988 | Link |
And now, for something completely different.
While doing a backup of a UHD disc, I decided to look and the INF file. I noticed that UHD_V3_MODE was set to 0. Since this is a UHD disc backup, you'd think that this value would be set to 1. |
#30989 | Link |
In BD-RD, is it possible to create a movie-only backup of an UHD BluRay, also adding an external audio track?
I own the 4K restoration of Escape from NY and i just wanna add my native language from the regular bluray: anyone knows hot to do it, please? |
#30990 | Link | |
I think this will work for you. I never made that for me, but it looks like a solution for your purpose. ![]() |
#30991 | Link | |
You do have to make sure, though, that the audio track you are inserting is in the same format as the one you are replacing (AC3, DTS, etc.). You also may want to select the language you will be replacing as the default when you run the job the first time. 2. If you are familiar with TSMUXER, an easier way would be to edit the meta file (in the working folder) and replace the reference to an audio track with the filename/type of the audio file from your DVD. Then just remux with TSMUXER. Note that this will only work on movie-only builds. Last edited by jdobbs; 17th December 2021 at 14:00. |
#30992 | Link | |
Of course, that option only shows up if you have UHD_CONVERT_ENABLE flag set to "1" in the INI file. Last edited by jdobbs; 17th December 2021 at 14:16. |
#30994 | Link | |
===================INI FILE===================== [Options] VERSION=0.61.0.25 ENCODER=1 MODE=0 ENCODE_QUALITY=0 ONEPASS_ENCODING=2 AUTO_QUALITY=1 TARGET_SIZE=47366 NVENC_CAPABLE=1 PRIORITY_CLASS=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=0 SD_TO_1080=1 IGNORE_3D=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=1 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AUDIO_DRC=0 DECODER=0 AVCHD=0 REMOVE_WORKFILES=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=1 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 FRIMSOURCE=0 COMPLETION_BEEP=0 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 PGSTOSRT=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23500 [Paths] WORKING_PATH=C:\USERS\NIGEL\VIDEOS\BDRBTEMP\ SOURCE_PATH=C:\USERS\NIGEL\VIDEOS\BDRBTEMP\IMPORTS\*************24(24)\ ============AUD.....AVS FILE=================== #Created by BD Rebuilder - v0.61.25 LoadPlugin("C:\Users\nigel\Downloads\BDRB 06125\tools\nicaudio.dll") audio=NicAC3Source("00000.track_4352.ac3").TimeStretch(tempo = 23.976/24.0*100.0) audio = (AudioChannels(audio) > 6) ? GetChannel(audio,1,2,3,4,7,8) : audio ConvertAudioTo16bit(ResampleAudio(audio, 48000)) =================LOGFILE=========================== [17:19:33] Importing MP4: ****************24(24) - Preparing MP4 for processing... - Collecting audio/video streams from source... - Converting audio, Track #2, EAC3 to AC3... - Building pseudo-BD source structure... [17:21:23] Video import completed successfully. ---------------------- [12/19/21] BD Rebuilder v0.61.25 [17:23:52] Source: *********************24(24) - Input BD size: 10.53 GB - Approximate total content: [02:17:09.763] - Target BD size: 46.26 GB - Windows Version: 6.2 [9200] - Resize: SD to HD 1080 enabled - Auto Quality: Very Good (Very Fast), 1-Pass VBR - Decoding/Frame serving: NVENCC - Audio Settings: AC3=1 DTS=0 HD=1 Kbs=640 [17:23:58] PHASE ONE, Encoding - [17:23:58] Processing: VID_00000 (1 of 1) - [17:23:58] Extracting A/V streams [VID_00000] - [17:24:15] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 197,317 frames - Bitrate: 35,000 Kbs - [17:24:15] Reencoding: VID_00000, Pass 1 of 1 - [17:33:42] Video Encode complete - [17:33:42] Processing audio tracks - Track 4352 (eng): Keeping original audio - [17:33:42] Multiplexing M2TS [17:34:11]PHASE ONE complete [17:34:11]PHASE TWO - Rebuild Started - [17:34:11] Rebuilding BD file Structure [17:34:11] - Encode and Rebuild complete [17:34:11] JOB: ******************24(24) finished. |
#30995 | Link |
While digging into an issue of trying to replace an audio track in a UHD backup, I discovered that BDRB did not restore the chapter marks, even though there was a CHP file in the workfiles. The meta file indeed had a tsmuxer option to do the chapter marks every 5 minutes. When I looked at the playlist with BDEdit, sure enough, marks every five minutes.
Why didn't BDRB not restore the original chapter marks? Is there an option I failed to set? |
#30996 | Link |
MrVideo, try
Create your BD folder Exchange the m2ts files, make sure replacement is named same as original Open BD structure in BDEdit Go to Playlist Correct audio Save Click on Apply to clpi Make sure info is correct If BDedit wants to correct CLPI allow it Save Exit Try disc |
#30997 | Link |
The idea was to try and fix a UHD of "Passengers" that has Cinavia audio. The source of the replacement audio is from a MKV file, which supposedly came from a Blu-ray. It may be from a DVDFab MKV build using their Cinavia removal. I played the MKV on my Sony UHD player and it did not get tripped up.
I first used eac3to to extract the audio in order to get the TrueHD remuxed. But, tsMuxer didn't like the audio, complaining that it had frame errors. I then tried mkxextract and tsMuxer didn't like it either. Same frame errors. Looks like I am forever stuck with Cinavia on that movie. Update: It would have been a wasted effort even if there wasn't an issue with the audio file. I think I may have found a bug in the new Sony UHD player. Playing the file via a thumb drive didn't trip the Cinavia detection. But, placing the file on a BD-ROM and playing that did. Cinavia detection is supposed to happen no matter how the material is played.
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 24th December 2021 at 22:58. |
#30998 | Link |
https://www.mediafire.com/file/72kdm...3to132.7z/file
Try using UsEac3to to re-encode audio from thd to thd+ac3, so you have a core in the track. Odds are that it will throw up some lossless check failed warnings, but ignore those and see if that helps Last edited by gonca; 28th December 2021 at 00:20. |
#30999 | Link |
As I mentioned, the audio track contains Cinavia. No recoding of any kind will remove it. The audio track also contains Atmos.This particular project is dead and done.
But, as noted above, I've managed to discover that BDRB is not restoring the chapter marks, but instead setting marks for every 5 minutes. I have to remember to restore the chapter marks with BDEdit. |
